t.ruckus.rex
- Joined
- Jun 20, 2010
- Messages
- 157
Finally starting to get this pile organized.
These are the best grade sockets coming out of Germany. Tooltopia.com has them new in case you want to have a heart attack (after you see the retail on them). My prices are, of course, much more reasonable.
None of these are full sets, so please read carefully whats included!
All prices include shipping within the lower 48.
I believe everything except lot 1 should fit into a USPS flat rate envelope to go overseas, I think they run about $30 depending on location.
With any purchase get a 32mm matching Stahwille wrench (or Armstrong or Wright) for only $15 more!
See my thread here (without socket purchase wrenches are $23 each).
http://www.garagejournal.com/forum/showthread.php?t=122071
Lot 1
Stahlwille 1/2 Socket Set in Case
$150
Case is a little beat, has no hinges and someone painted the inside insert a reddish tint. Insert is a little rough. Sockets are all in great shape though.
List of Items:
-Breaker Bar
-Ujoint
-Extension 10" OAL
-12 point sockets 8mm, 10mm, 11mm, 12mm, 14mm, 15mm, 16mm, 18mm, 19mm, 21mm, 22mm, 24mm, 27mm 30mm,32mm, 34mm
-Hex Sockets 4mm, 5mm, 6mm, 7mm, 10mm, 12mm x pieces
Lot 2
Stahlwille and Bahco 1/4 Set
$70
-Case is in good shape, has a sticky note on top that I'm having some issues getting out fully but it locks up tight.
-Stahlwille torx and hex sockets have a slight coating of rust/corrosion. Looks like from sitting too long
-Rest of the stuff looks barely used
List of items
Stahlwille
-Breaker Bar
-Ujoint
-6 point sockets - 5mm,5.5mm, 6mm, 7mm ,8mm, 9mm, 12mm
-Hex 4mm, 5mm, 6mm, 8mm
-Torx (complete) T8, T9, T10, T15, T20, T25, T27, T30, T40
Bahco
-6point sockets - 5mm, 5.5mm, 7mm, 9mm,11mm, 12mm, 13mm
-Etorx -E6, E8
-Hex 3mm,4mm, 5mm,8mm,10mm
-Torx -T25, T27, T30
-Phillips PH1, PH, PH3, PH4
-Flat 5.5 7mm
Lot 3 -$70
Stahwille Set includes
-Breaker Bar
-Ujoint
-12 point sockets 8mm, 10mm,11m, 12mm, 15mm,19mm, 21mm, 22mm,27mm, 32mm34mm
-6 point socket 30mm
-Hex drivers 4mm, 5m, 6mm10mm,12mm
Lot 1
$150
List of Items:
-Breaker Bar
-Ujoint
-Extension 10" OAL
Lot 2
$70
List of items
Stahlwille
-Breaker Bar
-Ujoint
Bahco
-Etorx -E6, E8
-Flat 5.5 7mm
Lot 3 -$70
-Breaker Bar
-Ujoint
