Dad gave me an old Hobart Meat Grinder
gbfan10
Minnesota
My dad had this old Hobart Meat grinder sitting around, when I mentioned I was going to process deer this year, he gave it to me.
I can't find much info on this, but it's a Hobart model 612. When he gave it to me it didn't work. I removed the gears in the gear box. About a cup of water and black sludge came out. I cleaned it all up, and changed the oil. I took the end plate off and cleaned the commutator (I think that;s what its called) and the brushes. Long story short, I got it going again.
My next plan is to repaint it close to the original colors, which seems to be red, with black stripes. I bet the thing weighs 60+ pounds. I am also going to replace the power cord..
Has anyone seen one this old? I am guessing 40's era? idk..
fatfillup
Finksburg, Md
Wow, congrats on getting it going!! It is definitely old, but I couldn't put a year on it.
Good luck with you processing!
G
gbfan10
Minnesota
I think this thing would grind up rocks if you put them in there.. I found one similar to it..
duke203
Hi I have the same meat grinder, by the serial number HOBART told me that this grinder is 1928. I sand blasded mine down spray 4 coat of two part epoxie primer, then 4 coats of black emron:shocking::shocking:
wil1964
duke203, can you post the contact information to Hotard, i have a grinder like this and would like to see if i can find out more about it. the serial # is 517704, its hard to read any other information on the information plate. thanks
smitty830
I also have a hobart meat grinder model # 612. Mine was stamped 1949 on the top plate in the spec box. I was wondering what type of gear oil you used. I have repainted and rewired a new cord . I also purchased new plates and cutters . We have used it to process our deer meat for the last 15 years and hope to use it for many more
sailor4you
Here is another vintage Hobart Meat Grinder. From the 1920's I believe, maybe a little earlier?
WWIIjeep
Arizona
tootsie
pittsburgh
Looking to buy a hobart 612 meat grinder for $35.
Any one have any comments or ideas on this machine?
Would also like to download a free owners and operator manual for it.
Thanks in advance
ndnchf
Fredericksburg, Virginia
Wow - those are cool, i'd love to find one myself. Interesting that these grinders appear to use the same type of switch that is used on my 100+ year old Kellogg air compressor. I took this switch apart and thoroughly cleaned it. It is beautifully made and has an 1895 patent date.
Mike.ASC
East coast
I know this is a old thread but....
I just acquired one of these Hobart Meat grinders with the exact same switch. I plugged it in and turned the switch on and it works , very quiet running motor. Any ideas on the best place to advertise it for sale?
sti4fun2
Lincoln City, OR USA
I acquired an old Hobart without the original motor. It is a #32 and has two handles on the base, one operates the two speed gearbox and another handle that I assume engages the drive (haven't fired it up yet). Is there anyway to identify it? I have looked at a thousand pictures online and can not find like it.
