Dear Garage Journal friends,
I am restoring my Reed 105 S and thought I would document it and make posts along the way. Actually, nothing new here and probably everything about restoring a Reed vise has already been written on GJ but I thought I would do this anyways. Here is the vise, it has "105" cast into the casting and there is a machined pad with the letter "S" stamped on it. I believe the S is for swivel. The vise weighs in at 94lbs and has 5 inch wide jaws. So far I have found no cracks or weld repairs and the handle is straight, the jaws line up good and not much in the way on any part of it being used as an anvil so this should be a short restoration.
The first thing I did was remove the set screw.
Next I soaked the 2 piece threaded collar with liquid wrench.
Next I used a punch and hammer to unscrew the collar.
I unscrewed the handle as I unscrewed the 2 piece collar and all of the sudden I had the 2 piece collar in my hand.
Next pull the main screw out. This vise had a .133 inch shim and not much lube on the screw.
Next remove the swivel handle and flip the vise over. All the sudden I can't get my photos to be smaller!!! Sorry I'll try to figure this out later!
I had to make my own extra large screw driver out of a piece of scrap sheet steel and a vise grip (hey don't laugh it worked fine..)
Here are all the swivel parts.
Next we remove the pin that holds the main nut in place.
On this vise I had to get the torch out and heat it a little, then hit it with a punch. Then I had to get a block of wood and knock the main nut out. This photo is getting ready to hit the wood and remove the nut.
Here is the nut and pin. In this vise the nut was tight as could be, absolutly not a floating nut. I think re installing the nut will be the hardest part of this job.
Finally all the parts went into the parts washer and then I put duct tape on the slide (ram). I am going to send these big parts to the sandblaster on this vise because I will be out of the country in South America next week. So when I get back they will be ready to paint. Normally I use electrolysis, a little sandblasting at home but this time I will send it out. Besides there is not much detailed lettering on this vise that I am worried about getting washed out from the sandblasting.
