3/8 Drive Spinner?
tez929rr
Welfare, TX
I find when working on my bikes I often wish for a 3/8 drive spinner. All of my hex and torx sockets are 3/8 drive; for brake and fork work (the calipers have to come off the change the front tire) I end up using the driven sockets a lot with a torque wrench. It's not a big deal; I ended up using a 1/4 drive spinner with an adapter, but since so many specialty drive sockets are 3/8 drive why aren't 3/8 drive spinners more common?
bobemmerich
Middletown, Ct.
SMKS
USA, planet Earth
I have this older Cornwell. It's a little ugly, but it works great. It's actually for sale. PM me if you're interested.
flintsghost
Colorado
Aside from the obvious driver handles, many shown here, there are the actual "spinners" previously mentioned that I have seen by several makers and own a couple. I have Snap On in 3/8" in both my traveling small tool box and my large main tool cabinet. They are readily found. I recently got a mint condition 1/2" drive model of the same design that is a Williams and I found it on Ebay. I'm sure Snap On makes one in 1/2" drive and I seem to remember that I have seen it in 1/4" drive though I have never used one in that size. I think if you look through some of the German makers like Hazet or Stahlwille, you'll find the same design in one of those lines in some size or another.
darkzero
SoCal
Good question. I'm sure there is some out there...somewhere.....But I haven't found one yet. That would be a handy tool to have....I think you're onto something there...:)
I jumped the gun here. Apparently they ARE out there...
http://www.universalcycles.com/shopping/product_details.php?id=27902
http://www.motionpro.com/motorcycle/partno/08-0496/
http://www.toolsource.com/drive-spinner-handle-p-111692.html
I second the Motion Pro T-handle. They make decent stuff & their tools are marketed for motorcycles.
T
tez929rr
Welfare, TX
I have that whole Motion Pro set. But the T-Handle is in the way (hits the brake disc) sometimes working on, for example, the axle clamp bolts.
I appreciate all the suggestions, everyone. Like I said, I am using a 1/4 spnnder with an adapter so it's all good. I just can't figure out why most tool makers seem to make 1/4 spinners but not 3/8. Every Craftsman or Husky or Kobalt or whatever 1/4 set comes with one, but never with 3/8.
That Blue Point one is nice. The Snap On with the normal lengih shaft is 50.00. Seriously?
fivespdcat
If you already have a 1/4" drive handle just get the 1/4" to 3/8" adapter and you're all set!
buffalobill
Western NY
you could always get a snap on palm ratchet and put knurled extensions on it. or a set of those nice Mac extensions that lock and have the comfort grip handle on the female end.
MattT
But they are just a handle drivers, where as the Vim above is a handled extension, so you can put a ratchet on it to pop it loose, or give it its final torque.
The female drive is a big improvement over a regular spin handle. Saves a lot of time not having remove the entire tool to switch sockets back and forth.
Steevo
43.49600, -112.04300
I have a couple of "T" handle ones I made from Craftsman extensions years ago (1970's).
I made them in both 3/8" and 1/2". I like the ease of spinning loosened fasteners by twirling the handle.
JSBriggs
Auburn CA
These? Didnt know they existed, might be worth a look.
-Jeff
ndoran
make one from a screwdriver handle and a 1/4 hex to 3/8 socket adapter drll the handle and tap the adapter into the handle - I made my stubby this way
Rico.
England
I tend to use a swivel ratchet in these situations. A 1/4 swivel ratchet with a
3/8 adaptor is very compact and really quick to use. I have the 72 tooth
Britool set and since I've had them I've haven't needed to use my spinner.
britool swivel ratchet by Rico UK
MAD
Western MA
Anybody own these? How well made are they? I've got a Benchtop 1/4 handle extension and it's my most used 1/4" extension. I'd love to get some 3/8" stuff.
Yes, I have them and use them all the time. They are high quality. VIM makes the MAC locking drivers others have suggested. The hard handle 3/8" and 1/2" drive ones from VIM are on clearance. I believe that sometime soon they will change over to the soft handle style like they make for MAC. The 1/4" VIM spinners have been the soft handle style for quite some time now.
Here is a link to the 1/4" drive VIM locking extensions (spinner handles) with soft grips.
http://www.tooltopia.com/vim-hd250.aspx
