Dave Nelson
- Joined
- Sep 25, 2011
- Messages
- 181
Looking for a good short or stubby bottle jack preferably under 7 in. collapsed. Any brands better than others?
I found this,went to Williams web, specs said minium 6 in. http://www.prohydraulictools.com/Pr...-On_12_Ton_Value_Bottle_Jack_Short_3S12TV.htm
Is Norco Made in the USA? Here is one that is 5 inch but you will need a loan for it.
http://www.alltiresupply.com/p-NOR-76637.html
Harbor Freight has a 12 ton, low profile bottle jack, model # 66569, but its minimum height is 7.5 inches. It is on sale for $34.99. Their 20 ton low profile also has a 7.5 inches minimun height.
Would you trust your life to a $35 discount jack? What about a 7-year-old or 10-year-old $35 discount jack?
Do not be fooled by high prices. Some expensive jacks are built like the cheaper jacks, only that they charge more for them because they are selling you the brand name. For example, Craftman sells a floor jack that is the same as the blue Michelin (with minor cosmetic differences) but at twice the price. There is also a new Blackhawk which sells for $200.00 which is the same as the blue Michelin. These three jacks are made by Shinnfu of America but the person that buys the more expensive one thinks that he got a better jack when in fact that is not the case. Remember the saying "buyer beware". For example, a jack like the OTC FLOOR BOSS is expensive but it is built using the same cheap main seal as the cheap China imports so the OTC's are as good or as bad as the China imports. All the OTC's use a cheap main seal ( except the rebranded Weavers) and everyone thinks highly of them because they do not know what is inside. Again, do not be fooled by name brands.
As for the quality of the machining of the jacks pumps, I have yet to find an import jack that is badly machined. Even the small trolley jacks or mini jacks show good machining. The problem with many imports is the quality of the seals used. With good quality seals an import becomes as good as any other jack can be.
Just because a Harbor Freight bottle jacks cost $35.00 does not make it instant ****. I have repaired $130 bottle jacks that use the same cheap main seal (ram seal) as the cheap bottle jacks. A good brand of bottle jacks is OMEGA, becuse they use real u-cups. These are also manufactured by Shinn Fu which, which by the way, also builds the HEIN WERNERS.
By the way, the Michelin, the Craftman, and the Blackhawk use a real u-cup so that, at least, is a good point about them. Just change the o-rings seals and they are great.
What about Milwaukee Hydraulic's
