Duracell ProCell?
robertwhite
Anyone have experience with the Duracell ProCell batteries (D size)?
I have always used the Duracell Coppertop for disposables, but am wondering if the ProCell's are better/last longer.
tyndall
They're the industrial version of the coppertop. Same thing as Energizer vs. Energizer Industrial. Same batteries sold in bulk packaging.
fr0mastaj
Yep, pretty sure its the same as the retail coppertops. But they are just packaged in bulk (paper boxes) instead for commercial use.
Duracell CopperTop
Get long-lasting, reliable power for the devices your business uses most. CopperTop batteries have been engineered to deliver just the right level of power for most of your electronic needs. CopperTop batteries are rated for reliable operation in temperature extremes from -20ºC to 54ºC and contain no added mercury. And they’re guaranteed fresh for 7 years.
Duracell CopperTop batteries are often specified for:
  • Flashlights
  • Portable Electronics
  • Remotes
  • Calculators
  • Smoke Alarms
  • Door Locks
  • Cameras
  • Wireless Mice & Keyboards
To fit virtually every device out there, CopperTop alkaline batteries are available in AAA, AA, C, D, and 9V sizes.​
Duracell ProCell
Duracell Procell batteries are manufactured to rigid specifications to meet some of the highest standards of durability and longevity that professional users demand and expect. Procell batteries deliver outstanding performance with a 7-year freshness guarantee backed up with date coding.
Procell batteries are rated for reliable operation in temperature extremes from -20°C to 54°C and contain no added mercury. They’re available in economical bulk packaging for easier inventory management.
Duracell Procell batteries are often specified for:
  • Pagers
  • Remotes
  • Flashlights
  • Calculators
  • Electronic Test Equipment
  • Door Locks
  • Electronic Safety Equipment
  • Cameras
  • Medical Devices
Procell batteries are available in AA, AAA, C, D, and 9V sizes​
metaldad
nw indiana
I am not ever going to buy a Duracell battery again, due to (it seems) a high rate of batteries corroding and ruining the device that they were installed in. (mostly Mag-lites with the OEM supplied Duracell, stored inside)
precisiontech
SoCen Penn
We use Duracell Procell @ work, no complaints about them. Usually on AA and AAA, have D cell but I personally don't use the D cells.
brtsvg
I've had exactly that experience with 2D MagLites but with Energizer batteries on about 4 occasions. Haven't found any of the Duracell alkalines to corrode and leak.
skeletonizer
I prefer the pro cells for the packaging alone. I use AA's for night vision, thermal imaging and digital camera. The pro cell packaging (four batteries per cardbard pack) is easier to open quickly and in the dark and is also easier to package into various gear stowage locations than the consumer blister packs.
I have noticed no difference in how long they last.
Greatbear
Columbia/Fulton, MD
Internally there is no difference between Procells and the Duracell copper tops. The big difference is in the packaging and the warranty coverage. The same goes for the Energizer comparable brands.
R
robertwhite
Warranty on batteries?
Send it, with the batteries, to Duracell for free repair or replacement.
And for items that you rarely use, and expect the batteries to sit for years, use lithium batteries. more expensive but with a 10-15 year in the flashlight shelf life. (I've had some go 20 years...)
TheGrooveking
An alternate reality in a parallel universe.
I've used the Procells at work for over 6 years, IMO they seem to have slightly less power than the off the shelf standard copper tops, but that maybe due to the vendors not moving much stock and them sitting for a while. As to Duracell corroding, I have over 8 Maglites piled up with that **** burst inside of them, I'll be sending them to them.
TheGrooveking
Duracell, Ray-O-Vac, and I believe Eveready offer replacement/repair for items damaged by their batteries leaking. I've replaced flashlights, and chargers multiple times. if it is a (Ray-O-Vac) rechargeable, they give you new rechargeable batteries also.
Greatbear, is the warranty more or less with the industrials?
89MustangGX
Stanwood, WA
Duracell CopperTop
  • Flashlights
  • Remotes
  • Calculators
  • Smoke Alarms
  • Door Locks
  • Cameras
Duracell ProCell
  • Pagers
  • Remotes
  • Flashlights
  • Calculators
  • Door Locks
  • Cameras
  • Medical Devices
I had to read both of those discriptions 3 times to make sure-- they are exactly the same! Except for some of the applications being different (?) they say the same thing. :wtf:
Adam
Greatbear
Columbia/Fulton, MD
From what I understand, warranties that cover the repair of items damaged by batteries is different between the consumer and the commercial product lines. No experience myself, but a friend had sent in some sort of device (I don't remember what it was) damaged by Energizer Industrial batteries and had issues getting things resolved because he was not a commercial user. It eventually was fixed, but was told he should stick to the consumer line if he wanted no hassles in the future. I think it had something to do with where he bought the batteries, it was not an authorized seller or some nonsense.
I have used both the commercial and consumer lines of most battery brands. The same "X will repair or replace any device damaged by X batteries if sent to X" exists on both product lines, so it should not be an issue. I've never tried to send something damaged by the batteries to any battery manufacturer, because many years ago a neighbor sent in a radio that was ruined by the batteries, it was sent back unrepaired saying the batteries were old and dead and should have been removed a long time ago. Those batteries were supposedly purchased recently and only been in use for a few months at best. I figured it was futile, since the mfgr always had an "out" of some sort. I've had everything from cheapass **** to expensive diagnostic equipment damaged by leaky batteries. In most cases I did what I could to clean things up and repair it myself, aside from a few catastrophes.
So far I've had 0 issues with returns. I think most have been Ra-O-Vac (Rechargeable) but at least one DuraCell.
If its a minor leak I'll clean it up myself using vinegar for any alkaline cell leakage. then rinse with clear water, and dry thoroughly, with heat as a final if possible. Coat all relevant surfaces with Vaseline, and normally it's good to go.
