So it looks like I’ll be adding onto my garage. Thus I’ll need to do something with the floor. The main garage has 4+ year old epoxy with the paint chips on it. The epoxy has started to chip off and wear out. It has over-spray from bead liner projects and kiddo (and dado) spray paint projects. The decorative paint chips means that if I re-coat the floor it won’t be smooth. Also I won’t be able to stain the floor due to the epoxy. I cut and weld, run floor jacks and jack stands on the floor…OK I’m VERY hard on the floor. What do YOU recommend to cover my floor with? Also, do you have any ideas on how to prep over epoxy?
Thanks
Thanks
