OccupantRJ
I was building a couple of wood cabinets today, and needed a way to plow 18 dadoes through the sides of the cabinets for shelving supports, so I made a guide for the router to make things easier and more accurate. It is simply 2 pieces of 1 X 6, along with 2 pieces of 1 X 4, assembled into a rectangle, with just the right dimension between the guides to allow a router to slide freely between them. The jig could also be built on an angle if angled dadoes are needed. Once the first dado is located and cut, it then becomes a simple matter to slide the jig to the next location, as the cut of the router through the wood of the jig becomes an accurate locator for the next cut to be made. I timed the cuts, and was able to easily make one complete cut per minute with this method, including relocating and clamping the jig. As an added bonus, the jig was made from free crate wood that my workplace gives me. Enjoy.
