charger891
I was definately in the need of a new work bench for several years now and finally scrounged enough used material to make a decent bench, i have a small garage and need all the bench space i can get, had the idea of using square tubing the same size as a receiver hitch to mount my vice and other tools, top of the 4 bench legs are square tubed, also used the round scraps i cut from the top as plugs when the tubes are not used, side og the bench i welded pockets so i can mount the vice, ect when not in use, left hand underside will have sliding drawers, the right hand will have a moveable welding table with a plasma cutting tray.
Before:
View media item 15881View media item 15870View media item 15871View media item 15872View media item 15873View media item 15874View media item 15875View media item 15877View media item 15876View media item 15878View media item 15882View media item 15883View media item 15884
Just have the drawes left and a few mounting plates to build for my tools and this part of the bench is done!
Before:
Heavy Duty is a slight understatement. Great job.
