Craftsman pro impact wrench help please
suss427
Iowa
This guy does not hit as hard as it used to...
http://www.sears.com/craftsman-professional-1-2-in-impact-wrench/p-00919905000P
00919905000-1
Is it worth rebuilding? Is there an Ingersol-rand rebuild kit for it?
Thanks
Obie
Indiana
Sears has that manage my life or whatever its called, you can look up the model number of the impact and it will show you all available parts and rebuild kits including a parts breakdown and manual. Before ordering parts though, try some PB Blaster air tool reconditioner. Works pretty good on restoring air tools if they've gunked up. And its cheaper than any rebuild kit.
Jbullfrog
Avoca, Iowa
Have you ever greased the hammer mechanism? That is what the little detent ball is for on the side. Try some air tool oil. Take it apart and inspect it for debri or damage and give it a good cleaning. It uses o-ring seals, so you can put it back together without new gaskets.
suss427
Iowa
It is definitely an IR2131, thanks for the tip. I have never greased it, only have run air tool oil through the inlet port. I had no idea that it had a grease port. Oh well.
What type of grease can I use... will aeroshell #5 or regular wheel bearing grease work?
The tuneup kits are 30 for the motor and 70 for the hammer. http://www.tooltopia.com/search.aspx?find=2131
I think I will just take it apart and clean/ grease it and if that does not help, just buy a new gun. Any tips for disassembly, cleaning, lubing, and reassembling one of these guys? I assume it is pretty straight forward?
Thanks for the help guys, this site is great.
DrkMtnDew
Just put a rebuild kit in one of mine, perked it right up, good as new. :thumbup:
wafrederick
Holton,Mi
The kit is a tune up kit,An IR tune up kit for an IR2131 will work having the same parts.Have air tool oil on hand lubing the o rings up.
