lzenglish
I picked up some stuff at a divorce sale last weekend, and these were in one of the boxes that I purchased for 10 bucks. As you can see, I got a 14.4 volt saw, and a 14.4 volt battery, which was D.O.A. Also there was this 18 volt battery charger in the box, that appears to be in great condition. I doubted, (in my own mind), that the 14.4 battery would fit the 18 volt charger reciever, from past experiences. But, after I checked the polarity on the battery, and the charger, plus the allignment slot configeration, Surprisingly it did fit in, "a little snug". I then pugged the charger into the 120 A/C outlet, and got the amber no charge light on the charger. I did some research on the net, and found that if this happens, you can rapidly plug, and unplug the charger, until you get a solid red charging light, which I did, and it worked. One hour later, I had a charged battery, reading 17 volts. I then I ran the saw under load, until the battery was drained, and recharged it overnight. MY QUESTION IS THIS: If this 14.4 volt battery goes into this 18 volt charger, would the newer "Ryobi plus one" 18 volt batteries work in this "Ryobi 14.4 volt saw" without any major down side effects? If it does fit, the only change I can see, would be an increase of the Saw Motor RPM, which may be a good thing, but I don't don't know for sure. What Say Ye?
Thanks,
Wayne
Thanks,
Wayne
