Hey all,
I am getting my garage structure up this week and planned on pulling my wire feeds through conduit I already buried. I have 2" conduit between the house and garage, about 100', with #2 Al wire feed for a 100 amp sub panel. I setup a few switches in the house to control the exterior lights on the detached garage and had some questions.
I am planning on running two 14-3 feeds along with the #2 main panel feed to control the two exterior lights. This way I can have a three way switch at both the house and garage to control them. Can I use interior 14-3 to pull through the PVC conduit or should I use burial cable for moisture concerns?
Also do you see any issue with using the same conduit for both the main feed as well as these two added power feeds?
The power feed is coming from the house panel and is a 15 amp breaker for 4 single bulb exterior lights and one halogen spotlight. Should I use 12 gauge for so few lights?
Thanks for all the feedback in advance,
smithl3
smithl3
