Bit Holders - What's your fancy
mobiledynamics
Gotham City
Tried the Wera and the Wiha. Not my cut of tea....
Call me old school but I still prefer a regular magnet extension Apex or a Snappy Tools Bit Chuck.
So for all you fancy schmancy bit holder guys out there, which ones are your guys using...
jjjrmx5
Cincinnati, OH
DeWalt, Apex and Wera.
I'm not a big fan of the bulkiness of the Wera with the rotator ring so it;s not often used.
Had a co-worker give me a shorty HF bit holder that was so &^%^ing out of round that it could screw around corners. LOL :lol:
Major suckage there and not a thing I will ever buy from HF. Wobble factor x1000.
Can't remember the chuck I have but it's fine. Nothing special but easy to switch to small drill bits with the 1/4" hex drivers and drills.
plinker
Northern Wi
I bought a Wera 1/4 bit holder that has a magnet. No issues so far with it.
Quality and function wise, It's miles beyond you newer Irwin or "cheap ones". I bought a couple for my Dad too.
I use Mechanics Time Savers for bit holders:
dwm
Southeast Michigan
It depends on what I'm doing. I like the action of the Weras but like jjjrmx5 I find their fatness significant enough to prevent their use in some applications. But I'm not very fussy about them; I've got several magnetic and slide-lock ones from the el-cheapos included with some long-lost driver sets to the expensive brands and don't notice a significant difference for use on exposed fasteners as long as I'm not using an impact driver.
I do like the Wera Impaktor a lot so far. I have the one with the ring magnet. It's bulky but works nicely for holding wood or drywall screws. I'm probably going to try the one without the ring magnet too since it appears to be considerably slimmer.
On the cars I don't seem to care; the fasteners I remove with power tools with 1/4" hex bits loaded are all easy access and I'm not changing bits very often.
mobiledynamics
Gotham City
Why the bulk - what's the advantage
Granted, the regular old school Apex I like has a way too strong magnet, the profile is slim to let you see the work. Small enough that you can nudge it in tight spaces.
Or is it because ya'll just like it stubby on the top.
t100
scrap aluminum stocks on a mill
or a piece of cabinet door with some hole drilled on it:
jjjrmx5
Cincinnati, OH
It's a locking collar which means it locks the bit in place but it also has a free spinning outter ring which allows you to control the bit at its base with one hand and a good grip vs. the std. chrome bit holder which you have to let spin in your fingers.
Good for running in lots of fasteners but you usually need the 50mm/2" long bits or the 70mm long bits to overcome the big mass of the ring if doing anything deep or anything close up as the masss of that coller gets in teh way physically or visually in many instances. A lot like trying to see around or drive a motorcycle vs. a Land Rover. LOL :lol:
It's all a trade off.
mobiledynamics
Gotham City
I've been trying to think of a application on where I would need to *hold* the holder.
If it's a custom cabinet, I'm predrilling anyway.
Anything else, it's just *rough* screwing for the most part, so as long as the bit is magnetic, I'm good.
