joshuaz223
here is a press i have been saving up scrap steel for for a long time. press will be 50 ton and so far i have purchased no steel for it which has dictated the design. original calculations showed the table was going to be very close the the bending state so i put the x bracing in it and the top. the one leg can be moved out to allow for a little more room if needed. a 50 ton enerpac cylinder will be mounted on a trolley that will slide between the uprights and a 20 ton enerpac will be mounted on the "C" end. the holes in the legs are 6" apart and the holes in the table are 4" apart leaving a 2" per step adjustment. still have to make the cylinder mounts and install the winch for raising and lowering the table. then it will get disassembled and given a black beauty blast and some paint. hopefully have it done in a few weeks.
i little secret i learned a long time ago is when hole sawing thick material to touch off with the hole saw so that you have a mark. then drill a few holes in the outer edge so that the chips can fall out without plugging up the curf and dulling the saw. i drilled all these holes (over 70" of steel) with one cheap hole saw and it is still sharp.
