My new go-to drill, a 1963 Craftsman 3/8"
jtbinvalrico
Tampa FL
Bought locally off a fellow who was deep into a VW resto when I dropped by (a cool benefit of used tool shopping :beer:). This is a 1963 Craftsman 3/8" single-speed drill. It ran just fine when I picked it up. It included the original cord which was in superb condition. A feature of this drill is a push-button lock that locks the spindle to allow easy removal of the chuck.....seems these drills could be used as powerheads for attachments.
Upon arrival in the shop:
From the 1963 Craftsman catalog:
The chuck screws on and off easily thanks to the spindle lock:
The gearbox:
The handle containing the switch assembly:
When assembled, you have access to one of the motor brushes on the top of the housing. Upon disassembly, you have access to the other one which is over the trigger switch:
....more to come.
J
jtbinvalrico
Tampa FL
Interestingly, these old machines were meant to be occasionally disassembled and serviced. Here's an oil port at the rear of the motor shaft:
More disassembly:
....more to come.
J
jtbinvalrico
Tampa FL
Before and after of the gears, these old metal parts really clean up nicely:
Re-assembly with fresh grease:
Be careful with the old plastic brush/spring covers, I broke one when I overtightened it.....fortunately I had some extra parts on hand:
I smoothed fifty years of use off the aluminum case pretty easily, using 100 gr for scraped and gouged areas, then working up through 1000gr and Mother's aluminum polish to finish. I wouldn't spend too much time chasing a perfect finish, though, these are meant to be used:
CRTDI
Wow!! That turned out real nice....:thumbup: What type and weight of grease did you use? Did you also use Mother's on the chuck?
ndnchf
Fredericksburg, Virginia
Very nice! Similar to the "Buck Rogers Ray Gun" drill I just refurbished. One worthwhile safety upgrade is to add a grounded 3 wire plug and attach the ground wire to the case somewhere.
J
jtbinvalrico
Tampa FL
I paid $30 for it. I'm hunting other oldies like this; when they pop up on eBay or the list, I'll pay 30ish for them....and they have to be running and serviceable.
For the re-greasing I used a lithium grease I found at the local Wholesale Tools. I'm not sure if it's the right grease or not.....for all the info I can find about these old tools, there's not a whole lot about what type of lube to use.
This one came with the original three-prong cord in great shape. The original catalog listing shows that it came with a two-prong adapter for those old wiring systems. You neglected to ground these at your own peril.....stray current has to have somewhere to go!
JimDon
Nice Score. I would not swear to this, but I think B&D made these for Sears. At least it looks a whole lot like an old B&D like I have. Back in the day, (and that one qualifies as back in the day) B&D made some of the best power tools around.
Cheers,
JimDon
ndnchf
They are neat. I picked up a craftsman 1/4" aluminum drill, original metal box and a bunch of accessories off Ebay for $10. Its in my queue for refurbishment and 3 wire cord.
Here's another one I have, its a "Speed-Way Electro-Magnetic drill" from the 1920s. It runs, but needs refurbishment as well.
So many toys, so little time.....
yasha32
I have the same one from the original post, I love it; torque is through the roof on mine it feels like an impact when you squeeze the trigger.
JASTECH
Gering, NE
I remember a B&D my Dad had, used it one time when just a lad and it had my arm twisted around yelling for help! lol, good memory.
B17E1943
Far Northern Kommifornia
Cheers,
JimDon
The first 3 digits of the model # is the source, which indicated who made it, but I don't see that in any of the pics.
Nice work on that! :thumbup:
