Helium Tank as Portable Air Tank
Jim Johnstone
Brantford, Ontario
Put up a picture, especially if you can find some stampings on the shoulder. Industrial helium cylinders are usually rated for 2015psi, but yours may not be industrial cylinders.
If it happens to be an industrial cylinder, all the info you need to know will be stamped on the shoulder. Get me a pic of that info and I can tell you what it means.
It works but the conversion is a pain in the ***. It is also not legal to convert those tanks for use with pressurized air. (So if someone is injured you would be held liable...)
The working pressure of the portable tanks is about 275 psi. what you are willing to risk is up to you...
He does not have an industrial cylinder so those pressures are not safe...
bczygan
DETROIT! Arsenal of Scrappers
He said he used 120PSI.
That's the one I was thinking. and yeah 120 sounds about right. I just don't like that type of tank for air much, They are SO lightweight, and have that damn blow plug. It would not take much to rust through one of those...
Also those handles are also supposed to act as a guard for the valve to prevent it's being knocked off, and they are just not up to it in a garage environment.
Jim Johnstone
Brantford, Ontario
Ahhh I see. I was picturing a small welding style helium tank like you can buy at TSC stores up here. I wouldn't waste my time with one of those things considering how cheaply you can buy an air pig.
geologist
I've seen a small compressor built using an old grill tank, but it was never a high psi setup.
tbobbo
Bismarck, ND
I have seen it done with old a/c 134 freon bottles, looks similar to that......................but I would not touch it! Even the cheap tire tanks are heavier built than that, if that tells you anything.
geologist
Come to think of it, I think the guy built one out of a freon tank as well. Yeah... I remember now.. a green DuPont tank.
RangerDaleXp
Commiefornia
I have not use those, but I did convert a couple of propane takes to use as air tanks. You need to wash them out though or the air smells like propane that comes out of them all the time.
G_P
Central CT
I have a couple of the freon tanks I picked up when they installed some new coolers at a supermarket.
I removed the **** plastic valve that was on them and drilled/tapped the fitting in the tank to 1/4" pipe thread.
They have been in use for over 10 years with zero issues being pumped up to 120 or so PSI. I would not trust them on a dual stage compressor pushing 175psi though.
Propane tanks work great too but they are heavy as hell and getting the propane odorant out of them is a PITA
Beemer
Northeast
I have a friend who was a career chemist working in a lab that gave me an air tank made from a helium tank a long time ago.
It resembled a 1/3 size propane tank but very light.
He was very meticulous so I didn't have any doubts about it's safety BUT it may very well have been something special for the lab setting.
I didn't use it much and now I really regret throwing it out because I have a need now and a converted propane tank is anything but portable to me. And he is retired so boo hoo. I wouldn't trust an import air tank without a safety standard listing .
PCustoms
VT
Holy 12 year thread bump....
You'd trust a converted helium tank, but not a purpose built tank because it was made offshore?
I wonder what the COO is for the helium tanks...
The Cobbler
helium tanks have a built in pop off in the tank so if they do over pressure it pops & bleeds off.
the . yes the metal is thin, and that would be a concern when it starts to rust . I am pretty sure they are thicker than the 1lp propane cylinders are , based on having cut both open and ( my memory)
rust in the eye
Chicagoland
Why all the hand wringing? Don't these carry higher(than 125 or so) pressure when filled w helium?
Don't they have the relief "plug" on them?
I don't think the failure mode would be explosive anyway. Correct me if I'm wrong.
Not just rust. Fatigue also; but also, inappropriate materials. PVC for you air lines? Not a good idea! Copper, or steel, yes.
PVC when it breaks, it shatters, and you get some really deadly shrapnel with razor sharp edges.
This is why pressure testing is done by filling with water, then adding pressure; if it does fail, the water. being uncompressible, instantly drops the pressure. Air and other gasses compress and store energy just like compressing a spring.
nadogail
Coronado, CA
I would "Proof Test It" at a multiple of my planned operating pressure then operate it at about half of the proof test pressure.
My first compressor was built with an Automotive Air Conditioner compressor and two discarded refrigerant tanks, the motor came from a washing machine.
LopezBart
Lopez Island, WA
If you want to make a portable air tank for use with 150 psi or so, there are lots of grill tanks kicking around. After removing the valve from a cylinder w/o external rust, check for rust inside (unlikely). Fit a cross, schrader valve, $10 air pressure relief valve and an quick release air fitting for attaching a hose.
These tanks are relatively sturdy since they need to withstand 300 psi (over temperature propane pressure climbs quickly). When they develop rust or other signs of wear, find another tank and transfer your fittings. Note that these tanks have a finite life.
You can use bleach to react with the mercaptan (odorizer) in the tank; leave the tank open when treating the tank. I'd treat the drainage as hazmat as chlorinated hydrocarbons can be nasty.
Aaron_W
That would be my main concern. They are very light because they are made for a single use and contain an inert gas. Repurposing the tank adds numerous new stresses, multiple refilling cycles, rust, wear and tear all well outside the conditions expected when it was engineered to hold helium, transport to the store and then recycled after use.
The phrase bare minimum comes to mind.
Aaron_W
Just had a look, portable 5 gallon air tanks rated at 125psi can be had for as little as $40 to upwards of $120 for a quality name brand. I'm all for saving money but a pressure vessel is not an area I want to be cutting corners.
Beerhippie
Far NE Oregon
Just throwing some **** into the scrap metal bin here and I notice someone has tossed a very good-condition "hot-dog" jobsite compressor in the bin. I'm sure the piston/cylinder went bad and the tanks are still fine. If I didn't own a nice little pancake comp, I'd make a portable tank from those.
Considering how short the jobsite life on most "oilless" comps is, I'm sure you can find a trashed one with perfectly good tank(s) for free.
If you want the one from our bin, come and get it.
