Wheel-Engaging Adaptors for Car Lift
utahrock
Utah
I recently installed a car lift in my garage and, besides the conventional way a lifting a car, I wanted to come up with an easy method to lift a car by the tires. I thought this would make many maintenance tasks easier and also give the ability to store the car like it was a four post lift. I like all kinds of tools and in addition to a CAD/CAM system and lots of design experience I happen to have a horizontal machining center.
Now there are one or two lift manufacturers that offer wheel-engaging adaptors as an option. But they are not very elegant, being heavy and ugly steel weldments and they don’t fit the tires on my sports cars very well. So I made these out of aluminum, 6061-T6 and anodized them. Everything is CNC machined and there is no welding. They were designed to have maximum tire contact to minimize the possibility of flat spots from prolonged storage. Each tire is supported by the two forks of the adaptors and so the tires have about twice the support area that they would have sitting on the ground.
Not wanting to drop an expensive car I did a finite element analysis which verified my initial calculations that they were very strong. The use of them results in somewhat more stress on the lift arms (because there is a twisting component) so the lift should be de-rated to about 50-60% of the normal capacity. My lift is 10,000 lbs., so that means I can use these to lift at least 5,000 lbs., which, while I won’t be lifting dump trucks, is more than enough for the sports cars they were designed for.
I like them so much that they have become the normal way I lift a car if I don’t have to take the wheels off. They have two big advantages:
1) The whole underside is accessible which makes removing undertrays and side panels fast and easy.
2) I can store a car with the weight on its tires just like a four post lift, but the two post takes up much less room.
I almost bought an in-ground lift, but for my garage I’m really glad I got a two-post. I have two cars in this garage, but also a motorcycle and I do some woodworking, too. The ability to leave a car in the air and park the other under it gives me a lot of room for the other things I want to do.
64dragnwagon
Northeastern Tennessee
Nice work! I never really thought about it but would it be bad to lift a car the conventional 2 post way with the tires suspended for a long period of time? What kind of problems could it cause?
jhelrey
MN
I like it! Granted, most of the work I do requires the tires to be hanging free.
rburke65
Canfield, Ohio
Utharock....very nice. Is that a Mohawk lift I smell? I bought a used one but don't have it installed yet....do you like yours? What would a set of these cost if one were able to have a set made? Thanks much!
U
utahrock
Utah
Some people say that suspension components can be damaged by hanging for a long time since they weren't designed for that. I think it probably depends on the car.
I like the adaptors so much that I usually use them. If I need to take off only certain wheels, for example on my 911 the right rear needs to come off for an oil change, then I just use a conventional lift pad in that position.
Yes, it's a Mohawk System 1. I like it but they are expensive, of course. I found a nice demo unit at a discount. It fits better in my garage than other, taller lifts that have a top plate for a cable. The Mohawk just has the hydraulic lines and they can be mounted so they don't interfere with the garage door opener. One point: Mohawk lifts are supposed to be self-bleeding, but mine didn't get rid of all the air on its own. I had to crack open a fitting to get the air out.
balddave
Western Pa, North of Pittsburgh
Well executed plan!
I'm concerned with the aluminum tho, did you give any consideration to fatigue? Even if you're below a stress limit of aluminum its only a matter of time before it fatigues and gives out, it might not be for 100's of years in which case you're well past the usable life of the rest of the system, but if the stresses are relatively high then it might be much sooner... Worth investigating if you haven't yet.
Good catch on de-rating the lift, lots could over look that aspect.
nehog
Jaffrey, NH
AFAIK, no vehicle can be damaged that way. I lift vehicles for long periods of time (I use my 2 post for storage in the winter.)
Vehicles are made to handle full droop, with force, which can happen in many driving situations. To think that gentle dropping to the stops would damage something is not very logical. ;)
abstamaria
Manila
Full-droop storage
One torques the metalastic or bonded rubber suspension bushes on some cars at ride height. At ride height, therefore, there is no twisting of the rubber in the bushes. At full droop, the bushes are twisted and strained. Accordingly, the common wisdom is never to store a car in full droop position. Most car museums, high-end storage facilities follow that rule. I suppose a car with rod-ends, as in racing cars, can be kept on full droop.
U
utahrock
Utah
Well executed plan!
Good question on aluminum fatigue. I've been designing rock climbing and technical rescue equipment for a long time (see my homepage if you're interested) and most of it is aluminum because weight is important. The right alloy in the right use doesn't suffer from worries about fatigue. In fact, we also make some steel equipment and they can suffer their own problems.
For example, carabiners are made from 7075 aluminum which is much more brittle than the 6061 I used on the adaptors. But even so, we can load a carabiner to half its breaking strength 100 times, which generates an impressive amount of stretch and warpage, and then when we test it to destruction there is no reduction in ultimate strength. The adaptors use a much more forgiving alloy, but they are also quite stiff so there is very little flex, far below any critical amount. There are no sharp corners that can act as stress risers; the forks are one piece and the junction between the angled part and the square section sandwiched between the top and bottom plate has a nice, big radius cut with a 3/4 ball end mill.
Because of the alloy and the lack of stress risers, if the adaptors were overloaded they would tend to bend rather than suddenly break. If this happens, the mechanics of this would result in the load moving inward, which would reduce the force causing it to bend.
When I test new climbing gear I'm naturally apprehensive when I'm hanging on it over a big cliff for the first time. I felt the same way when I lifted my expensive car for the first time. But I approached it the same way, calculate it first, then test it. I had a cheap car I could have tested it with, but I was confident enough that I just put the Porsche on.
The picture below shows how much the adaptors incline when loaded. But this is not all due to flex in the aluminum. Over half is caused by the inner lift arm rocking in the outer lift arm, because there is some clearance between them. Some flex is caused by the inner arm twisting along its length. The farther out it is extended the more it twists. Some more flex is due to the adaptor rocking a little on the end of the lift arm. I tested it without tightening the bolt at all, but in normal use I snug them up. Very little flex originates in the aluminum itself. In the picture, that's the heavy end of the 911 and the load on that wheel is about 1050 lbs. and the angle is reading 2.5 degrees.
admranger
Las Vegas, NV
Re: Full-droop storage
Exactly. This is why you set bushing with the wheels under full vehicle load (or you get to do it all over again in very short order).
It doesn't hurt for short periods of time, but you don't want to hang a car off a lift for months on end...
Oh, and UtahRock, the mod is very slick. However, 1050 lbs per corner? Time to put your p-car on a diet! My X5 makes those kind of scale loads.:D
U
utahrock
Utah
That's only on the rear. The front wheels are a little over 600 lbs. each. Still, you're right, a 993 turbo is not a light car...
akdiesel
Wasilla, AK
That is a great idea and very nice craftsmanship.
As for the twisting effect and the de-rating of the lift due to it, dont the two post lifts have the twisting element already in place at the base of the arms? I am sure the companies have calculated the safety factor in for this, but a 50% de-rating for your improvement?
tonycastec
Los Angeles
"The picture below shows how much the adaptors incline when loaded. But this is not all due to flex in the aluminum. Over half is caused by the inner lift arm rocking in the outer lift arm, because there is some clearance between them. Some flex is caused by the inner arm twisting along its length. The farther out it is extended the more it twists. Some more flex is due to the adaptor rocking a little on the end of the lift arm. I tested it without tightening the bolt at all, but in normal use I snug them up. Very little flex originates in the aluminum itself. In the picture, that's the heavy end of the 911 and the load on that wheel is about 1050 lbs. and the angle is reading 2.5 degrees."
Here's a suggestion to fix this on the next set you make !
Design the forks to angle upward by 15 degrees ?Would this help?
There are some great ideas for whee/tire engagement among the tools the "Repo" tow truck drivers use.
240sxguy
Madison, wi
Nice car and very cool idea for your lift. Another big advantage that nobody has mentioned is at full lift height the car sits a little higher. At 6'2" often times I have to duck under a lift and this could solve that problem.
U
utahrock
Utah
Yes, it is very conservative and I am sure it would go higher safely. I guess I was so conservative because I can't find any vehicles I want to lift with the adaptors that weigh more than 5,000 lbs. anyway. I sized them to fit perfectly on car tires (specifically sports car tires) and consequently they don't fit very well on truck tires (although if you jack up a truck tire a little to get the adaptors under the wheel it will work). For testing purposes I lifted my Avalanche using two of the adaptors on one axle and two regular pads on the frame on the other axle (the wheelbase is 130" and the arms don't extend far enough to use the adaptors on both axles).
15 degrees would be too much. You could go 2 or 3 degrees and then they would end up about level when loaded. But the slight downward inclination is not a problem at all. It actually increases capacity because it moves the load inward. I did my calculations at a worse case senario so the downward slope makes the load rating even more conservative.
Yes, that's a good point. I'm 6'2" also and the extra working height is very nice.
Britwrench
Brighton UK
Neat, the only thing that concerns me is the sideways force of the tires against the forks as the vehicle is lifted.
Could you have a "fork within a fork' so that any sideways movement was taken care of?
U
utahrock
Utah
There is not much sideways force on the forks compared to how thick and wide they are. The force is roughly in the middle of the forks so there is much less leverage than if it was at the ends. Nevertheless I did the strength analysis assuming the force was out near the ends. There is some leverage, of course, but there's ample material in the forks and the tensile strength of 6061-T6 is over 40,000 psi. I've measured the flex in the forks and it is really minor, far below the elastic limit.
tonycastec
Los Angeles
Idahorock :your adapters are so well designed that I wish you would contact [email protected] -who is JSK on this forum - to get them made in volume. They offer the convenience of a 4 post with the space-saving and access of a 2 post. They solve other issues too. I am sure he would forgive you for buying a Mohawk!
U
utahrock
Utah
I'll do it - thanks. I need to look at a BendPak lift. We are in Utah. If anyone has a lift located from Salt Lake to Ogden and they'd be willing to let me take a look please contact me.
tonycastec
Los Angeles
If you need to see Bend Pak lifts -just contact Jeff. That is exactly how I came into contact with him. At the time I was interested in full-rise scissor lifts but eventually reasoned that a wheel engaging 2 post would be better.
Let us know when you invent your next tool!
U
utahrock
Utah
Nice job, how much for set?
I see a business opportunity.
Thanks for the encouragement. I'd love to be able to make a production run. If we can make them fit some popular lifts, maybe we'll be able to.
I've written to Jeff but haven't heard back, yet. Hopefully I will and I can look at a BendPak and try it out.
Yellowmann
Utahrock, Wow those are amazing... I was looking at a 4 lift post for storage but I am a big DIY person and 2 post would be best. So any updates on production of your creation? I also contacted Mohawk about pricing and just waiting for a reply. I know its going to be $$$ :( So if you are making these, I might be able to get a 2 post lift with this option.
TIA,
Y
Strouty
Southern Maine
TIA,
Y
Mohawk will sell you a set, but as you fear, they are expensive. They are also heavy as hell, so these would be nice if you wanted to switch back and forth.
Yellowmann
That is good to know they are heavy... I doubt I would be getting a Mohawk since I'm on a budget. Just looking for other options beside a 4 post lift.
tonycastec
Los Angeles
For anyone interested in the wheel engaging lift idea that Utah Rock designed, you may be interested in this video of one of his competitors who sold a system to Jay Leno:
Enjoy !
RSwannabe
I'd like to take a moment to say Thank You to Rock! I shamelessly copied his design and produced my own set of these. Mine are not nearly as pretty as Rock's as I don't have access to CNC machines, but I think they came out pretty well.
I made mine out of 3/4" 6061 aluminum plate top and bottom that I had cut by a water jet company next to my office. I then routed the edges and used a (manual) milling machine I have access to to counter sink the bolt holes for flat cap Allen bolts (grade 12 M10's), and rabbiting the lower plate for engagement for the 1 1/8" pin (DOM 5 tube) with a 3/4" bolt running through it that threads into the bottom plate.
I made the arms out of 3"x 3" 6061 aluminum square stock that I cut with a bandsaw using a 1" 2-4 TPI bimetallic blade and then did a little extra routing to ease the edges so I don't open up my scalp WHEN I hit my head on them. In the pictures you can see the wood jig I made for the 45 degree longitudinal cuts with the bandsaw.
I finished the machining of all the components yesterday and assembled the first one. I'm quite happy with the end result. I expect to test them this weekend.
tonycastec
Los Angeles
Bend Pak or Greg Smith should have bought the design/tooling from GJ member Utah Rock.
These are the absolute best piece of equipment I ever bought.
