parts washer fluid
atotalnincompoop
thunder bay
what are you guys using in your parts washers?
i bought a 40gal unit from greg smith equipment and would hate to have to buy 40g of varsol for it.
is there something bettter, a concentrate?
LutzTD
Lutz, Florida
I just bought one recently, I was thinking simple green for mine, all the old stuff is pretty caustic and volitile, plus expensive to have evaporate away between uses.
spongerich
Monroe, NY
I use simple green in my little home shop washer. It's pretty cheap, and much less toxic than a lot of the alternatives. Once in a while if something is really gummed up, I'll have to hit it with some more aggressive solvents, but it works pretty well on most things.
Shadowdog500
Down the shore
I use PSC1000 from tractor supply. It is really good stuff! This stuff hasn't evaporated away and Ive been using it for about a year and a half. The grime seems to settle to the bottom after a few days so Ive been using the same fluid since Oct 2010 with no noticeable evaporation.
Don't put a water based cleaner (like simple greene) in a metal parts tank unless you want your paint peeled off and tank rusting out.
Chris
Kerosene works well and if the setup is covered, does not evaporate much at all, I keep a cover on the drain hole of the washing basin when not in use.
If considering Simple Green make sure it is compatible with the tank/pump seals. I feel like this is a better choice for water based solvent setups, but I like the results and use SG a lot.
Matt M PA
SE PA
I have an older Gray Mills machine that was given to me...with the big top lid. It had some fluid in it...so I only needed about 5 gallons (I think about $100) to top it off. I haven't noticed any evaporation or odor, either. It's on the second floor of the garage and you wouldn't even know it was there.
(Frankly...I have so little use for it...that I wish it wasn't there sometimes.)
LutzTD
Lutz, Florida
Chris
that seems pretty reasonable at $8/gal. I wonder how I would test my pump for simple green or this stuff? The ultimate test would be to try it and fail but then the cost goes way up.....
Shadowdog500
Down the shore
Did you buy this parts washer?
If so, you want a solvent and not water based cleaner.
The Tractor supply stuff is a parts washing solvent like Safty-Kleen that a lot of shops use.
Read the manual and see what it says to use. Also be aware that the advertised tank size on part washers is usually the volume that the thing would take if you filled it up till it was flowing over. My 20 Gallon Tractor Supply model only took a little under 10 gallons to get it to the shelf.
Chris
Full Throttle
if any of you know somewhere to get Bio-Diesel it is a pretty good solvent, much better than Dino Fuel.
I like the tractor supply stuff as well
SGKent
Citrus Heights CA
Stoddard Solvent aka mineral spirits aka white spirits aka Safety Clean as far as I understand. I believe that Safety Clean makes sure the environmental and safety standards are met at the sites for the solvent and also picks up and re-refines the old solvent to reuse it. I've never found anything that works better but wear specialty gloves cause after years of using it your hands will react to it.
fatboy99
Indiana
40 gallon's would fill that parts washer to the top. 15 gallon's should be enough to operate the washer on. I have a 30 gallon washer and have 15 gallon's of the tractor supply solvent in it. Keep the lid closed when not in use that keep's the evaporation to a minimum.
A
atotalnincompoop
thunder bay
Chris
yes this is the one, perhaps i should read the manual:D:eek:
A
atotalnincompoop
thunder bay
i still have 10g of varsol out of my old washer, its still good, i could reuse that. i read someone a long time ago that guys would add water to the varsol, the varsol would float to the top, all the dirt would fall through the varsol and settle into the water layer, helping to keep the varsol clean. anyone heard of this before?
NUTTSGT
Northern Central Ohio
I had Simple Green in mine. The instructions recommended a bio-friendly solvent, so I figured Simple Green would work. It ate the paint off.
Mine has been sitting empty for a few years because of this. I'm not sure if I should try to paint it again but I don't know what to use ? Maybe a gas tank sealer product?
When the time comes, I'll be buying the stuff from TSC like Shadowdog posted. A friend uses it in both his parts washers and has good luck with it.
pmason0
East Tennessee
I bought PSC1000 from Tractor Supply for mine last fall, but its still setting in the can on the garage floor :-( But will need to break it out soon, need to rebuild some CV joints.
Shadowdog500
Down the shore
Yes, some people put water at the bottom of the drum style parts washers so the **** settles to the bottom into the water. Some people put a junk carpet at the bottom of the tub style ones so the **** settles into the carpet.
I really like the TSC stuff because the dirt does settle to the bottom after a few days and the fluid stays fairly clean.(I don't use it daily so it has time to settle) I just let the **** settle to the bottom of my tank and If I don't disturb it it just seems to stay there. I also use cake pans from the dollar store as a parts basket to soak small items and wipe the **** layer from the bottom out with a rag after pouring the fluid back. Since I'm paying for the fluid I try to keep the **** that goes into the fluid to a minimum. I'll wipe the gobs of grease off with a rag before soaking something in the solvent. Funny I never thought to do stuff like this when I wasn't the guy paying for the solvent.
Chris
weaponizer
I find it odd that Tractor Supply says PSC 1000,is "not for use" in their 20gal Jobsmart partswasher SKU 3907887...
Shadowdog500
Down the shore
That actually came up here before. For some reason that particular portable parts washer says to use an eco friendly, water based fluid in the footnotes even though it says to use solvent in the product description. It has the same pump, tank, and thermal fuse as the other no portable models, and is made to use solvent. Some (including myself) believe that the lawyers added this note to give themselves an out since solvent can easily slosh out of that portable unit onto the ground, which would pollute or catch fire.
I have that same portable unit and had solvent in it for a year and a half now, and you can't jostle it around or you will get solvent everywhere since the tank is shallow.
Chris
metalmagpie
Seattle
Used paint thinner. Free off craigslist. I top it up every 6-8 years. Housemates complain when I do a bunch of washing, 'cuz of the odor, though. Before that I used $uper Agitene, wow, heavy spendy.
Mmfh
MEMBER EMERITUS
Portland Oregon
I've been using Mineral Spirits in mine for as long as I can remember. Once I heard that Safety-Kleen used it, I switched and stopped using their expensive service each month.
Wes Tex
What an interesting question with interesting responses. I have used napatha for at least 40 years before the pump driven washers became popular. I find it to be cheap (about $6.00 per gallon), and it does not have a strong odor. In the old days it was used by dry cleaners. I still use it in my pump driven washer. It is harder to locate, but I have found several distributors that still sell it. I just hope they don't declare it illegal for some reason and stop selling it.
RTcat
South Central Wi
Chris
X2 - I'm currently having good results with this product.
Falcon67
Merkel, TX
I have a 20 gallon unit from HF. I used 10G of mineral spirits in it plus one quart of ATF. Used to buy the fluid at Lowes (paint thinner) but TSC PSC 1000 is cheaper per 5 G can, per the web sites.
LutzTD
Lutz, Florida
my washer is a pretty old one out of a dealership, I have no idea the pump seals or construction. I dont want paint coming off so I guess simple green is out. Im liking the TSC stuff after this post. Mineral spirits is about the same cost but it evaporates pretty quick. I bought it about half full of mineral spririts so I may just end up topping it off
LutzTD
Lutz, Florida
whats the ATF for? what kind of carpet? I would sure hate for it to come apart and clog everything up or melt and add some kind of extra suspension in the fluid
That would probably be difficult to do. it is used EVERYWHERE and under many names (some in conflict with other different petro products from one country to another...)
You should be aware that naphtha does not leave any oily residue (other than what has broken down and been absorbed by the naphtha...) so rusting can be an issue after cleaning bare steel parts.
I use the stuff fin my camp stove collection, so made this up some years back:
And for what it is worth, some references and notes on the volatility of different petroleum solvents:
and lastly some notes on non-petrolatum "solvents". Note that SG is nearly 80% water...
Yes, it does work. I used a coffee can in the bottom of my home built cleaning setup, and put the water in there; mainly to contain it so it wouldn't rust out the bottom of the 20 gallon barrel i used. I used a bathroom sink drain/tail and extended it to the coffee can. I had plans on gluing some Scotch Brite to the top of the coffee can and just leaving a small hole in the Scotch Brite so it would act as a crude filter, but never got around to it. Seems to work anyway.
1fastvx
Oops, never saw that. I have the Crown PSC in the exact parts washer they say not to use it in. No issues here yet....hopefully it is written in the manual since it is portable.
:shocking:
John
Falcon67
Merkel, TX
The ATF gives it a little oil and makes it somewhat easier on your skin. ATF colors the liquid (paint thinner is clear) and is also a great detergent. I clean cylinder bores, decks, freshly machined surfaces with towels and ATF.
