L1430T Baldor motor wiring, I need help please.
Beeroh
Hello, new to board, I have a L1430T Baldor, its a single phase 230v 5hp motor and I am trying to wire it for my 80gal 2 stage compressor. What I don't understand is everything, from do I need a starter, if so what kind and specs, do I need an on /off switch, how do i wire the motor with 4 leads coming out? Thanks.. :willy_nil
Stainless169
Fort Smith, AR
Wish I could help you with your question.
I would suggest you posting this in the electrical section of the forum. Lots of experienced guys in there eager to help.
Good Luck.
coby65
Monterey Bay area
You will need a pressure switch that will have 220v coming in from the panel. From the pressure switch to the motor you will need wiring also.
Make sure you get right pressure switch to turn the motor on and off at the correct pressure and get pressure pop off valve rated for the tank
Hope this helps!
Steevo
43.49600, -112.04300
The wires in the connector box should have numbers printed on them.
They should be numbered 1,4,5 and 8
If you want it to spin clockwise when facing the shaft end of the motor, then you connect the 230V hot lines like this:
Line 1 goes to 1,8
Line 2 goes to 4,5
For opposite rotation (CCW facing shaft end):
Line 1 goes to 1,5
Line 2 goes to 4,8
You'll need a pressure switch capable of handling 25A or more, or else you will have to use a lesser pressure switch to trip a starter switch that is capable of the amperage load.
Beeroh
thanks everyone for their knowledge, I ordered a Seimens Magnetic starter and now understand the schematic of the motor.. Ill post results.
thorgy
I have the same set up. Did you ever get it up and running and if so could you post the wiring diagram? Thanks.
