Modular
4300-3144 RJ45 connectors 8/8, 8/6, 8/4
4300-3132 RJ11 connectors 6/6, 6/4, 6/2
Turned Pin
4300-3147 Turned pin connectors 0.14-4mm²
4300-3148 Turned pin connectors 6-10 mm²
Endsleeves
4300-3127 Endsleeves connectors 0.25-10mm²
4300-3153 Endsleeves connectors 16-25 mm²
4300-3154 Endsleeves connectors 35-50 mm²
Insulated Terminals
4300-3129 Red/blue insulated connectors, 0.5-2.5 mm²
4300-3128 Green/yellow insulated connectors 0.1-6mm²
4300-3258 Red/blue heat shrink connectors
4300-3262 Green/yellow heat shrink connectors
Open Barrel
4300-3150 Open barrel connectors, 0.1-0.25/0.25-0.5/0.5-1.0 mm²
4300-3151 Open barrel connectors, 0.5-1.5/1.5-2.5 mm²
4300-3146 Open barrel connectors, 0.5-1.5/1.5-2.5/4-6 mm²
4300-3202 Like 4300-3146, but crimps are lower and wider
4300-3709 6.3 mm Flag Terminals 0.75-2.5 mm²
4300-3427 6.3 mm Flag Terminals 1.0-2.5 mm²
4300-3348 8mm Flag Terminals 1.0-2.5 mm²
Closed Barrel
4300-3241 Non-insulated connectors 4-6/10 mm²
4300-3142 Non Insulated connectors 0.5-6 mm²
4300-3137 Non-Insulated connectors 0.75-2.5mm²
4300-3139 Non-Insulated connectors 4-10 mm²
Coaxial
4300-3136 RG58, RG59, RG62AU, BNC/TNC Coax connectors
4300-3141 SMA, SMB, SFR, ST, SC Fiber Optic connectors
4300-3140 RG174, RG179, BNC/TNC Coax connectors
4300-3138 RG6, Belden 1694A, Twinax BNC, CATV F type connectors
4300-3386 CATV connectors RG6, 59 Sqr 1.72/Hex 8.23 mm
4300-3181 BNC, TNC connectors RG6, Belden 8281, 1694A Hex 1.73/8.23/6.48 mm
4300-3247 BNC, TNC connectors Sqr 0.7 Hex 3.85/3.25 mm
4300-3182 BNC, TNC connectors Sqr 1.07 Hex 8.23/6.48 mm
4300-3249 BNC, TNC connectors Sqr 1.72 Hex 5.41 mm
4300-3459 BNC, TNC connectors Sqr 0.73/1.72 Hex 3.25/4.30/5.41 mm
4300-3460 BNC, TNC connectors Sqr 1.20 Hex 3.25/4.52/5.41 mm
4300-3404 BNC, TNC connectors Hex 1.73/2.03/2.54/10.90 mm
4300-3403 BNC connectors on BT 2002, 2003 cable Hex 1.46/5.18/6.81 mm
Proprietary
4300-3727 Metri-Pack 150 & 280 type connectors 0.75-1.5/2.5-4.0/4.0-6.0 mm²
4300-3242 Weather Pack type connectors 0.5-0.8/1.0-2.0/3 mm²
4300-3706 Automotive type connectors with Wire Seal 0.5-1.5/1.5-2.5/4.0-6.0 mm²
4300-3707 Automotive type connectors wrap-around crimp 0.5-1.5/1.5-2.5/4.0-6.0 mm²
4300-3708 Automotive type connectors over-lap crimp 0.5-1.5/1.5-2.5/4.0-6.0 mm²
4300-3541 Solarlok, turned pin type, 2.5-4.0/6.0 mm²
4300-3540 MC3 Ø3mm, turned pin type, 2.5-4.0/6.0 mm²
4300-3539 MC4 Ø4mm, open barrel type, 2.5/4.0/6.0 mm²
4300-3426 TE/AMP Timer type connectors without Wire Seal 0.5-1.0/1.0-2.5/2.5-4.0 mm²
4300-3425 TE/AMP Timer type connectors with Wire Seal 0.5-1.0/1.0-2.5/2.5-4.0 mm²
4300-3428 TE/AMP SuperSeal 1.5 System type connectors with Wire Seal 0.75-1.25/1.5 mm²
