Facom J.360pb Rotator Ratchet
mambo
Anyone have one or has used one? what are they like? how useful?
SMKS
USA, planet Earth
krc328ic
Maine
I have a S.161 and its ok. It's fairly heavy and it takes some effort to change the gear direction. Not the first 3/8 rachet I reach for. My F80 is!:bowdown:
djkeev
North Western New Jersey
I have the Blackhawk in my box. Have usd it? Yes. Do I often use it? No.
Why? As mentioned it's heavy, the handle is huge, overall bulky. I like the fine mechanism but am not sure if I've ever encountered a practical need for the rotation aspect that can't be met by a 1/4" drive unit.
Bottom line, more of a novelty in my box than a needed tool.
Dave
Qualitytools
SOCAL
I have the Stanley and the Facom and Love them both. The Facom has a nicer handle! The Stanley handle is a bit difficult to clean but some WD40 and it's good to go until the next time I need to use it. I end up using my Stanley a lot just for the fact that it rotates.
wvrailroader
West Virginia
You can get the Bostitch version at Walmart for about $20. It is the same as the Blackhawk and Stanley ratchets.
Sent from my SM-G900R4 using Tapatalk
Know Wosad
I have a 936 Blue Point. Why I have no clue.I suppose because it's "cool".It's a well made piece. YAY !
I also have one of those goofy Craftsman V ratchets like a handle on a trailer jack. Same reasoning..or lack of. Something else to talk about and better than a missing finger I reckon.
Fedwrench
Valley of the sun
I have the 3/8 drive blue point sitting in a box at work. I don't think I've ever used it. It's a little on the heavy side. In this day of thin head ratchets and ratcheting wrenches being available in so many versions, I really don't see the need for it but, that's just me. I guess it's better to have it & not need it, than to need it, & not have it:dunno:
Superbec
Netherlands
I have a turning 1/4 proxxon , I used it only for spark plugs and it makes a hard job easy.. if you have a vehicle with the new type spark plugs with 2" of thread on them and a few cylinders are hard to get to and one is just impossible... well this is the tool for that job.
mrborohachi
Berdoo Route 66
I have the Stanley version. Picked it up for $6 at a swap meet. I'm planning to use it on front wheel drive timing covers that are right next to chassis frame.
Heres a good video of a real life case where this style of ratchet works wonders. Where you thank god you have one/creates a need of owning one (GJ tool want addiction)
<iframe width="560" height="315" src="https://www.youtube.com/embed/H0UlteANG6k" frameborder="0" allowfullscreen></iframe>
Ole Slewfoot
Freedom, CA
I have the Stanley one, its good on 2000's VWs where the front is 1000 10 mm screws down in a crack. Definitely more of an obstruction wrench that a 1st tier tool.
tony p
London UK
I have the Facom 3/8" Rotator (J.360). Not used a lot (it's quite bulky), but I find it's more than a gimmick; smooth, nicely finished and genuinely useful for a couple of jobs (awkward-to-access suspension adjustments on a track car) which I've done with sufficient frequency for them to become tiresome without it.
What may not be obvious until you've handled one is that in 'twisting-the-handle mode', turning the handle back doesn't just recover its position - it carries on turning the socket in the same direction as you twist back and forth.
Is it worth the money? Hard to say - as I got mine along with some other stuff from a tool-merchant friend in return I did a small job for him, so it wasn't an easily quantifiable 'purchase'. I have quite a lot of Facom stuff (mostly older French-made items) so I was already well-disposed to the brand.
