Walls are up inside and Finished
ScSilverDak
I finally have gotten my drywall work finished and painted, and all the trim work completed.....
The next step is the Dropped ceiling and overhead fans and lights.........
Then prep work to finish the Flooring.....
Kevin54
MEMBER EMERITUS
Urbana, Ohio
OK! Am I missing something or are the windows on the floor? Or is that lights in the wall? Looks good though. If it is light, why did you put them so low? If it is windows, what's it look like from the outside. So many questions, so little time. LOL!!!
sammerdog
West Michigan
Most paint shops I've worked in have always had the wall mounted lower lights, but your room looks too finished to use as a spray booth. I'm courious on your use of the plastic backed sub flooring. Do you have a problem with moisture wicking up through the concrete, or something else? Different idea, never seen it in a garage.
ScSilverDak
The additional lighting from the 2'x4' T8 4 bulb lights make detailing my Dakota easier because I can now see better....
No more Paint Swirls!
The Concrete floor is uneven and it makes leveling it out so I can apply flooring tile Smoothly alot easier, plus it creates a finished look to the garage.
ScSilverDak
After more than a year later I'm finally able to get back into working on my Shop......
we started with Finally installing my Ceiling and overhead Lights.....
some of you may notice a hunk of steel in the shop already, it's my next project!
Next up will be installing the wall cabinets, and making plans to build the new work bench....
thomask
Sunshine State
Thanks for the photos and updates.:)
Tell us some more about that little metal project we see there.:confused:
Looks like a early 70s MOPAR am I right?:bounce:
mrb
i see some things horribly not right in this picture. Mind posting a pic of inside the switch (looks like a fused switch, but may be a panel -cant tell from the angle) the yellow romex cables are entering?
ScSilverDak
Circut breaker box and Fused circut panel......
it has two pull out modules and the old type screw in fuses, but it all is wired properly..
Local electrician and contractor looked it all over and it's up to code, plans are to eventually upgrade the box and add a circut for baseboard heaters later on........
mrb
the unsecured romex entering through that conduit ****** (or whatever that is) is not ok or up to code..........
Is that SO cord in the upper left (the two black cables entering the 4S box)?
Mike83
Wisconsin
At least he has a drip loop! lol
Seriously, though, doesn't the romex need to be stapled w/in 6" or so of where it enters the box?
jdcompman
South Dakota
I'm not sure about your part of the country but where I live it is also against code for those boxes to be covered with the white doors you have there.
mrb
that, and id be worried about the SO cord if thats what it is. Cant run it through walls (for good reason -the insulation becomes brittle and falls off)
Hansson
Sweden
-68 Charger, I got one of my own in similar condition, maybe more rust on mine.
/Henrik Hansson
ScSilverDak
Well I've had 3 Contractors, all of which are Pa certified and registered, the local electrical inspector has been in and signed off on it, my Home owners insurance has had a inspector over and he's signed off on it.
The work on all this was originally done in early 90's by my Grandfather, and all we did was add a couple circuts that the box had the capacity for.
as far as the cabinet doors go, no one has said a word about it other than it
finishes the shop off nicely....
This isn't a commercial garage by any means, it's also set up so I can shut the power off to it from main house 30 ft away.....
