If I had a day job, I wouldn't be quitting it
Olyar15
Bowser, BC
So, the various posts on porcelain tiles have inspired me to do the same for my new garage. Decided to try my hand at tiling for the first time, and things are going much slower than anticipated. It is not quite as easy as what I saw on the various DIY shows on HGTV, that's for sure.
So far, I have spent about 5 afternoons working on it, and have almost finished laying down the intact tiles. Then I still have to cut the tiles along the border and lay them.
First 2 days:
3rd day:
Today:
Closeup of the tiles I'm using:
Hopefully, at the rate I'm going, I'll be done before winter.:D
jhelrey
MN
Your taking your time to do well! Of course it will take longer!
O
Olyar15
Bowser, BC
Looks great! What are you using to transition to the outside
Thanks. Right now I'm not planning on any transition, just ending the tile at the edge of the garage floor. Unfortunately, the driveway was already a bit lower than the garage floor, so the addition of the tiles makes for a bit of a ledge. I might try making a bit of a ramp with any leftover mortar. However, I have also been thinking about doing a stamped decorative concrete surface on the driveway in a couple of years, depending on the budget. So that might bring the level up to the tiles.
Get those garden implements out of there!!! ;)
Yes, I've ordered a plastic shed to get the garden tools out of the garage. House is newly constructed and not quite finished, so there are still a ton of jobs to do around the house and yard.
jonesmechanical
Lehi Utah
So good to see tile. I think it is the best garage floor solution. I am in the process of ordering porcelain rectified 24"x24" tiles. I am also going to do it my self and look forward to it. About 2000 sq ft total, but unlike expoxy, you can take your time doing it.
You are inspiring me. Unlike expoxy, your tile will look this good in 10 years.
kngkong
Wellington, New Zealand
Thanks for posting this it's looking great. Am thinking about doing the same in my garage and appreciate the work in progress pics. Like the layout you have done with the darker strips. Nice job.
red
Hudson Valley, NY
Looks great! Definitely don't want to quit your regular job. When I was a kid I worked with carpet installers. Their knees were as big as their necks. And their bodies were well used. My son is a plumber and I see the wear and tear his body is taking. What color for the grout?
red
Hudson Valley, NY
The larger the tile the more difficult it is to install. There's a kit out that helps keep the extra large tiles flat or level to each other. You may want to consider using this-
Lash Tile Leveling Clips-
http://www.homedepot.com/h_d1/N-5yc...&langId=-1&keyword=tile+spacers&storeId=10051
GtiKyle
PNWet
Where are you ordering your tile from, and at what sq/ft price? I've got roughly 1200 sqft, and i've seen prices in the 3-4k range even if you bargain shop around...
darkk
Willimantic, Ct.
I just did a bathroom floor with *Made in U.S.A.* Porcelain tile and got it from Home Depot. It was only about $1.60 sq. ft.:rocker: I think if you order in bulk, you can get an extra 10% off.
Jagmandave
Overland Park, Ks.
With that light color you'll need carpet squares under your tires or you'll leave some brown/black marks over time, you'll also see tires marks where you drive in each day.....
I had tile in the showroom of a Porsche dealership and while it looked great and held up well, there are things you need to do it daily to keep it that way.
One of the big advantages of epoxy is not having to put down the tire protection.....
Jack Olsen
Los Angeles
It's looking great! I've seen some of that wood-look tile before, and thought it would be cool for a deck. But I never thought of using it as a border element like you're doing -- that's going to look awesome.
I guess some tiles are vulnerable to this -- and I don't doubt Jagmandave had it happen. But I haven't had it happen, and I've got the cheapest ceramic tile Home Depot had in stock. My father's shop has epoxy -- I think he's on his third covering. Sooner or later, he always ends up with problems where the tires sit -- and also in spots where there's too much drip-off water and salt in the winter. I think he might also have issues with his 1969 pad and its moisture barrier.
As a data point at least, here's my experience. I've never done anything other than blow off my tile with a leaf blower and clean up the places where I've gotten paint overspray or spilled/dripped grease or oil. On the last engine rebuild (and exploded CV joint), I just hit the section under the lift with some spray cleaner and everything came right up. It's been the easiest-to-maintain surface I've ever owned -- and I've had it in use in my garage for over four years now. I have no moisture barrier at all, and my slab was poured (poorly, I've got to admit) in 1925.
The color of mine is pretty light. I've never seen a tire leave any kind of a mark on it. I raise and lower the car (which has very soft compound track tires on it) all the time. Maybe the surface of the Porsche dealership tiles was matte?
Here's a list of things my floor has been exposed to without any damage:
• Mineral spirits flooding it when pumping the stuff through my car's oil lines.
• Sulfuric acid dripping down from when I acid etched my steel bench top.
• Rolling a 500+ lb engine on top of a Sears floor jack.
• Dragging sharp stuff over it. (jacks, steel stock, car parts, heavy cabinets)
• All kinds of paint.
• Gasoline.
• Paint Stripper and Brake Cleaner. (Both of these can contain methylene chloride, which will dissolve many epoxy floors.)
And of course, hammer blows. Here's the video: Tiles Meet 4-lb Sledge
There's nothing wrong with epoxy at all. It looks awesome, and when it's properly installed it is a very durable surface. But I think Olyar15 is going to be very happy with these tiles.
O
Olyar15
Bowser, BC
Floor almost finished
Well, I finally finished the floor. Just have to seal the grout and clean off the grout haze from the tiles. Then a wash and rinse and it's done.
Some pics of the floor. Don't have an overall view because of the stuff in the garage. And the NSX had to go back in to recharge the battery.
NSX seems right at home on the new tile:
This area will have a row of Ikea kitchen cabinets, so I didn't tile it (plus I was running out of tiles). I plan on bolting a piece of wood to the concrete to act as a ledge for the base cabinets.
Not sure what to do with the steps. Might tile the sides to match.
So glad it is finished. I made several mistakes, and it is far from perfect. It is one of those "good from afar, but far from good" jobs. Still, I can claim is as my own, including the mistakes.
slickgt1
+2 with what Jack said. Best lowest maintenance floor I have ever had. **** I use brake cleaner on it when things get really oily. I also used a wire brush to remove paint over spray.
Tile the steps. Go to hardware store, buy hardi board, cut it up to cover up the steps. Make sure you glue it, (PL Premium is my go to adhesive), and screw it. Then tile it. You will never think about it again.
jsraaf
Twin Cities MN
Looks really nice, great job! One question though - isn't that going to be slicker than snot when it gets wet?
slickgt1
A bit when soaked. Only time I find mine slippery is when I wear crocks or some footwear that it very plasticky (sp). Sneakers, boots, dress shoes seem to be ok.
Also, its not like you are going to soak the floor and then go running all over it. Any floor will make you bust your *** in those conditions.
Just saying, pushing two years now, and never slipped accidentally. Only slipped when testing, and that was with a freshly hosed down floor.
Dmaxman
Montreal, Canada
Looks good! I would rather have mistakes on my garage floor than my kitchen or bathroom. So crack open a beer and give yourself a pat on the back and say good job!
sxk122
Dallas, TX
If you drop a wrench or hand tool and the tile breaks, chances are you've installed it wrong. My favorite oh **** moment was when I dropped a 4 qt. Pyrex bowl in my kitchen just weeks after laying new tile. The bowl bounced twice and ended up on the dog bowl mat.... tile and bowl were both fine....
slickgt1
Wouldn't there be a big concern with droping anything on the tiles and having them crack in the garage?
Search for jack olsens vid of him hitting hit tiles with a mini sledge. It is not as easy as you may think.
maxspeed96ct
Love the NXS !
Tile looks good, I asume you dont do much mechanical work in there. Cause I would think the tile would go to hell fast. Its tough to clean food stains out of my kitchen grout, I cant imagine cleaning out oil and grease.
slickgt1
Love the NXS !
Search my name, and Can your floor do this. This should be the last time you say that, lol.
