billymade
re: TM936 head conversion; normal 1/4" square to bit drive?
Hey, I've noticed the TM936 ratchets are the same as the other 1/4" 936 ratchets with just slightly different drive guts. I was wondering if anyone has done a conversion on their "normal" T936 style 1/4" ratchets with a rebuild kit; the only difference I can think of, is the Cover Plate. Anybody tried it and is the Cover Plate the same or need to be swapped, modified? Any info appreciated! I have enough 1/4" ratchets; that this conversion would be a easy way to have another style of ratchet without buying another ratchet altogether. I'm thinking; this is overdue for a dual 80 (72 tooth) update soon as well; anyone seen these yet? Any info appreciated!
Links:
Set, Magnetic Bit and Ratchet (6 pcs.)
Stock#: TM936SET
http://buy1.snapon.com/catalog/item...roup_ID=681921&store=snapon-store&dir=catalog
Description:
Repair kit for TM936SET and GTM936SET Ratchet and Bit sets.
Kit, Ratchet Repair Stock#: RKRTM936
Links:
Stock#: TM936SET
Description:
