Two Post vs. Four Post Lift
Richard D
Texas City, between Houston and Galveston
I realize there is a LOT of info on lifts, but I did a search and didn't find anything specific. I am planning to install a lift behind my house, which will be accessed from a narrow alley. I am thinking the two post will be better, not just because of the sharp 90 degree turn to get a car in there, but also because it is easier to pull the wheels with a two post. The two posts also just strike me as higher quality. Comments?
wit2003
Geneva, OH
There are many people on here that may have a better answer for you, but what i ccn contribute is that I would go with a 2 post(and i did).
My reasoning was that I wanted to be able to do work on the car that required taking the wheels off. You can get a jack for a 4 post that will lift the car off the wheels as well, but i just preferred the 2 post.
If your looking for a parking solution also, then 4 post would be better.
Hope that helps some.
Mmfh
MEMBER EMERITUS
Portland Oregon
I like a drive on rack for just that reason, you can just drive on. No getting down on the ground and setting the legs to the right place to lift the car. Used to not be a big deal, but as you get older and stiffer getting down on the ground like that isn't as easy as it used to be.
The air lifts on the drive on racks are great too for doing any kind of wheel or brake work, easy to lift the car up off the rack, also a large horizontal surface to lay out all of your parts. Don't have that surface for everything you remove with the 2 post.
My 2 Cents
Mm
EOC_Jason
Bentonville, AR
Generally you see 2 posts for work because of the easy tire removal and other minimal blockage by the four legs. While 4 posts are more for doubling up vehicle storage because it's easier to just drive on / off.
It's not to say that you can't do vice-versa with them, it's all about what you think would fit your particular application better.
R
Richard D
I'm thinking the racks(the part you drive on?)will be in the way when doing brakes, shocks, springs, and other suspension work. Is a bit of a pain moving the arms under there, maybe put some convex side mirrors(like on 18 wheelers) on there? Mark the floor with different color paint for the cars lifted most often?
Falcon67
Merkel, TX
Friend used to own a car shop - he had one Bendpak 2 post and 3 4 posts. Mostly they used the 4 posts for work.
torquepower85
CA
It is generally considered that a 2-post is better for working on your car (more under-car access, wheels free). Though you could park on it, it's not suggested to leave the suspension hanging for an extended period of time.
A 4-post is considered better for parking a collector car. Though you can do work on it, it's a little more difficult than a 2-post.
It all comes down to what you plan on doing with the lift, and what space you have to accommodate such lifts.
KPSquared
Wetaskiwin, Alberta, Canada
4 post good for oil changes and parking. . .that's about it. 2 post is pretty much unlimited with nothing in the way. The ramps on a 4 part are in the way all the time. I hated trying to do anything on a 4 post, they're just not convenient.
If you just want the lift for doing work and it's going to be outside, go 2 post.
383 240z
Findley Twp. Allegheny Co.
After 15 years as a line tech, I learned a few things, first off 4 post lifts **** for everything except for oil changes and lube jobs. cant use them for suspension work, or pulling engines from the top. There is no way to roll an engine crane over the forward cross member.
I am eating brown bag lunches saving up for a 2 post lift, I was offered a few 4 posts for free and I dont have them, if that tells you anything. Keith
mayday0017
Houston Texas
Very good topic, I'll be following it for sure!
Always liked the storage of a 4 post lift but they seem to be in the way more when not in use. Also looked like a 2 post lift could adjust to accomidate anything I would want to lift not just a car/truck.
Not in a position to buy either at this point in time but do dream of one day owning one and will be nice to already know what I want.
Cryptic1911
Willimantic, CT
For the OP, I think a 2 post is best because of the space situation
but, I don't see why some of you guys rag on 4 post lifts.. they aren't just for parking. If you have a rolling jack, you can do just about anything. They may be a little more of a hassle involved with some, but to say they are only good for oil changes is a bit ignorant. We've done plenty of oil changes, exhaust work, suspension work, pulled transmissions multiple times, etc.. And pulling a motor out the top is no problem. The only thing I can see that would be a pain in the *** is dropping an entire front member with the motor on a fwd car out the bottom.
We're completely happy with our 4 post.. didn't want to have to deal with the arms and lowered cars
blk00ss
Haven't seen anyone mention this yet. But a 4 post is the only way to do exhaust work. But I'm getting a 2 post myself.
Crusty Nut
Suspension is at ride height for exhaust work. If you snake a pipe around with the axles hanging, nothing will fit when the car is on its wheels.
Engine work is easy with a 4 post. Just raise the lift 6 inches and roll the cherry picker under the front crossmember. trans work is easy too.
I recently got a 4 post after years of planning on getting a 2 post. I made the right decision for me. both work well, both have pros and cons. The rolling jack adds to the cost, but adds way more in versatility.
dirttracker18
Slate River, ON
When I was working as a tech our shop had mostly 4 post lifts and the 2 post lifts rarely got used.
Those saying 4 post is for oil changes and parking have never worked in a pro shop.
They both have many pros and cons and can be situation specific. The only limit on a 4 post is when the engine needs to be dropped from below. It can still be done but it is much harder. Other than that, space and smacking your head are the big drawbacks for 4 post, that and cost. Considering the need for a good rolling jack or two.
I am struggling with the same question myself.
Falcon67
Merkel, TX
I don't know what the deal was, but him and his main mechanic usually worked off one of the 4 posts. Even for brake jobs and such. They had a big tray with air jacks on it, so I suppose that helped with that.
bd8134
Franklin, MA
For a regular front engine/ rear wheel drive, a gearbox removal on a 4 post is ok.
A 4 post with front wheel drive, gearbox removal would be complicated.
A solid rear axle removal or gas tank could also be more complicated.
A 4 post takes up more garage floor space.
I am not sure why they say you should not store a car on a 2 post.
The hanging suspension rests on the stops so the springs are not compressed.
The tires are not resting on the ground maybe causing flat spots.
I have multiple friends who store their cars / work extended times with a 2 post.
Just curious.
I have a 2 post and love it. I spent a long time deciding 4 or 2 post. It was certainly 4 post at the beginning. If I get another lift now, it will be a 2 post.
A ball on a string attached to the garage door for positioning your car works great.
darkk
Willimantic, Ct.
Not true at all. I just did a front end on our truck and then due to wear recently had to do rear spring shackles. Not difficult at all with a rolling jack.
Really? What did he consider the pros and cons? I can't remember ever seeing a four post in a pro shop, thought is was more of a consumer-grade item.
Really? Jay Leno ring any bells? Has has about as professional a shop as anyone, he even has Bend Pak 4 posters.
QUOTE=KPSquared;2426488]4 post good for oil changes and parking. . .that's about it. 2 post is pretty much unlimited with nothing in the way. The ramps on a 4 part are in the way all the time. I hated trying to do anything on a 4 post, they're just not convenient.[/QUOTE]
You're not very coordinated are you? Where do you guys come up with this?
Another uncoordinated mechanic...
So far from the truth it's funny
A man with some intelligience....finally!
There are advantages to both types of lifts, It's just a preference and the type of work you are comfortable with doing on a specific type lift. I worked for 50 years in the auto industry and have used both. You can use either with ease for the majority of auto related work.
blk00ss
There are advantages to both types of lifts, It's just a preference and the type of work you are comfortable with doing on a specific type lift. I worked for 50 years in the auto industry and have used both. You can use either with ease for the majority of auto related work.[/QUOTE]
Arrogant much?
zmotorsports
Northern Utah
After working with both I prefer a 2-post for almost all of the work under a vehicle. It seems like the rails on a 4-post get in the way more than anything else.
I know there are pros and cons to both but I installed a 2-post at my home shop and don't regret it one bit.
Mike.
metaleltr
Western Ohio
Although your suspension work can be done with a rolling jack it would be simpler without the ramps in your way. I'm sure your going to call me an uncoordinated mechanic, but sometimes you need to work smarter not harder. IMHO there is nothing a 4 post can do that is easily done on a 2
villardk
I need a 4-post lift to store my vettes (75 and 76). I also want to work on them, as well as, my Dodge Grand Caravan van. I need to do an engine change and the van has to be lifted off of the engine versus pulling it from the top. Will I be able to do that with a 4-post lift?
torquepower85
CA
You should be able to do that. Depends on if it will clear the runways, I'm betting you'll be fine.
Falcon67
Merkel, TX
If you have a big four post like my friends old shop - one that can handle a good size service truck, 3/4~1 ton or so - then a pip squeak front drive car apparently has plenty of room. I've seen more than a couple of cars on his racks with engine/front drive cradles sitting on the floor under them. Now at the Lincoln-Mercury dealer where other hot rod friends work, most of that front drive work and truck body popping is done on 2 posts. So youse pays your money and youse take your chances :lol:
tool-guy
victoria, australia
Another thing to consider when toying with the idea of purchasing a hoist is how much room you actually have. A two post hoist, you can walk past or through it when not in use, a four post hoist, you either have to walk around it or over it. Depending on exactly where the hoist is located, you may be walking past it or over it every day where as your vehicle maybe on it once a week or less. Just my .02cents worth.
sunshine1639
One thing That pushed me to the 4 post, other than storage was the fact that I needed to be able to move it from time to time and the only place I could put a lift was going to be in the way at times.
The Max Jax looks nice but wanted more height.
Finally went with the ProPark Plus so my truck can be parked under it when It is not in use or one of my sons cars is stored on it.
For me this works but in the end it is what you feel is going to serve your needs the best
Good luck with your decision
Dave Maxwell
Kickapoo illinois
I'm going 4 post that way I don't have to anchor it down. When I'm done with a car on the chassis table I can roll the lift to it and roll the vehicle on the lift and to the ground
rackeu
In my opinion the above is the major 4 post advantage: potential to move it around. if you have limited space a two post is the way to go as a two post although permanent its footprint takes Much up less shop space
Dave Maxwell
Kickapoo illinois
Cheaper than a fork lift for me. Buddy has one and he is 6'4" and walks under it without a problem is what I also like. I used to work at dealerships and was always hunched over.
Steves32
I have a 2 post at my shop- 4 post at home.
4 post is Bend Pak HD9 w/ rolling jack.
I prefer the 4 post & I own both.
I like the 2 post for lifting a body off the frame but that's the only time I use it now.
I don't do FWD cars- just hot rods so that may make a difference for some.
PDM
Coquitlam, B.C. Canada
I just closed down my race shop of 12 years, and I had 2 Rotary 2 post lifts, and one 4 post Rotary alignment lift, and I used my Rotary 12K - 4 post alignment lift about 85% of the time. I love that lift and was the one I kept in storage until I rebuild my home garage to re-install my 4 post with alignment rack.
I did a lot of suspension work and alignments, and found the speed of the 4 post to get very low street and race cars was so much faster than using blocks and centering on the 2 posts. (one 2 post had under 8 hours of actual use it was essentially brand new when I sold it, and used it mainly to keep project cars on.) I also had 2 large center jacks on my 4 post, which were strong enough to lift most trucks also.
Plus I love the use of the 4 post as your working "workbench" for brake and suspension work. Handy to lay out all the parts and tools at work-level vs having to roll work carts and tool boxes near the 2 post.
4 posts do give you a larger footprint - so if you space is a concern, look at possibly scissor lifts (you lose more under-working area though)
2 Post lifts are generally cheaper, and are easier for engine swaps.
As stated - both have their pro and cons .....
