Much more complete now
MongoTom
Southeast Michigan
Back in February I posted this thread http://www.garagejournal.com/forum/showthread.php?t=130860&highlight=mongotom with several photos of our new garage. Since then, much has happened.
After my wife and I wired the garage, we had open cell foam blown into the structure.
ry%3D480
After we had it drywalled, we finished the wiring, installed the lighting and I painted it. We sunk troffer lights in the ceiling to maximize the ceiling height. In all there are 40 T8 5000K 4' bulbs, 24 down the center and 8 on each angled side wall. The light in there is perfect.
ry%3D480
The floor was coated with epoxy and polyaspartic polyurea and looks great.
ry%3D480
My wife and I installed knee walls in the loft and then put down our first and last tile floor. I like the way it turned out. I've since installed some shelving and am ready to start storing off season items and the like up there. I'm planning to get a chain fall to attach to that outside beam to move large, heavy items.
ry%3D480
There are motion sensitive lights on all four sides of the garage.
ry%3D480
The gutters flow into a 100 gallon water barrel in the back, next to the generator. We built a platform to raise it above the level of our raised bed garden, so we could gravity feed that.
ry%3D480
We installed a small (8,000 btu) window air conditioner. The place is so well insulated that it does a fine job of keeping the temp and humidity under control. The doors are wired into the home alarm system as are the heat detectors on both floors. If things get nasty out there, we'll know it right away.
This entire project has gone great. The only thing I'd do differently is the interior paint. I got clever and used fire-retardant paint and it's just awful stuff. I wouldn't do that again.
MongoTom
Southeast Michigan
Mostly car work. Repairs, upgrades, detailing and more. The boiler for the floor will go in this fall and a four post lift next spring. I'm going to look for an older Miata or something similar to set up for track time.
Not knowing exactly how we'll use the space, I'm not attaching anything to the walls. No cabinets, etc. Everything we use for storage will be on wheels so it can be pushed out of the way. Even the four post lift will be on casters. I'd like to get a compressor and that will go in the loft.
