Media Blast Cabinet (Glass Bead Cabinet) Build/Experience
porschedude996TT
Santa Maria, California
I bought a Harbor Freight Abrasive Blast Cabinet Item #93608 thinking that it would work. Silly me, no, I always need to fix the design before the item will work. Full retail was $299.99 and it was on sale for $209.99 and with a 20% off coupon it came to $168 plus tax. Not bad for a metal cabinet, a light, and a window. I assembled it and tried to blast some paint off a project I was working on. It didn’t want to flow any glass beads. I went to the HF site and saw some reviews. One stated that the feed tube was a welded seam tube full of weld splatter and that it prevented it from flowing properly. Yah, right, what a bunch of hooey that was. I read another review and they stated that the only way was to buy an improved pickup tube for $100 and that would make it work. Yah, right… Then I found another site that sold an upgrade that included a better gun, a foot peddle control, a pressure regulator, and a much better media mixer. The mixer is the real secret. It allows air flow to occur as it needs to be. It can be best explained like a vacuum cleaner that is dead headed. Lots of vacuum, but no flow. If you have a venturi that allows flow and it will pick-up the media. I hooked up my shop vac thinking that I could use it rather than buying a mounted and dedicated vacuum unit. After the initial trial trying my shop vac with you original media pick-up tube I found about 10 pounds of media in my shop vacuum. So I purchased a HF Media Recovery unit Item #94275 for $149.99 and 20% off equals $120.00. It worked great and it doesn’t loose much media. I didn’t like the idea of hoses running through the side of the cabinet using a grommet so I bought some aircraft bulkhead fittings and it works great. I also added an air only nozzle to clean off the parts. I think now the unit is working as it should have.
So for just over $600 with tax and shipping the blast cabinet is working well.
Cabinet $168.99
http://www.harborfreight.com/40-lb-capacity-floor-blast-cabinet-93608.html
Reg/gun/venturi pick-up upgrade $198.00
http://www.ebay.com/itm/UPGRADE-KIT...TROL-Sandblaster-Blast-Cabinet-/261072777583?
pt=Sanders_Sandblasters&vxp=mtr&hash=item3cc926716f
Vacuum Media Recovery $119.00
http://www.harborfreight.com/blast-cabinet-reclaimer-kit-94275.html
Fittings $60.00
I finally got the files uploaded, problems with cellphone.
Last thing I plan to do is seal all the seams with RTV. They really did a bad job from the factory. The RTV is just coming off in 6 inch strips.
uniballer
bedford, va
? prices must be different in va. but i bought cabinet for 109$, dust collector for 55$. from hf, and media was 10$. ca must have shipping increases!
NUTTSGT
Northern Central Ohio
I'm glad I only paid $75 for my "Clarke" unit froma scratch and dent section. I 'm using a small 2 gallon shp vac and have never had a serious amount of sand in the bottom of it.
I'd guess you have the vac on the side hole and the back hole open for the air intake ?
P
porschedude996TT
Yes, I was using the wrong port, the one on the back has a shield that reduces the direct airflow and only picks up the lighter weight pieces.
mayday0017
Houston Texas
Hm.... interested in one of these TP Tools kits for my cabinet now, Sounds like you are very happy with the upgrade?
P
porschedude996TT
How well does the HF dust collector work? I need to add one but will probably look at TP Tools.
Works pretty well, it adapted to my model with out much fuss. It ***** the glooves in like a pro and it collects the media well. The media that is collected is not the dust. The dust (powdered glass beads) is collected in the paper filter. I have not cleaned out the filter yet.
