l_bilyk
I emailed a representative form JET (the company that made my impact wrench) asking if it's true that the wrong type of socket can actually damage the hammer. Ignore the sales pitch
Thank you for your inquiry. Chrome molybdenum actually contains vanadium as one of it's
components, the addition of molybdenum is an enhancement. Chrome Molybdenum steel is used on the
best grade impact sockets as it is more malleable than chrome vanadium. This allows more precise
heat treatment (JET sockets are heat treated in 9 stages) and helps to absorb some of the impact.
Chrome vanadium is a harder steel and when used with impact tools tends to shatter when
overloaded. Chrome vanadium steel is more suited to hand tools such as wrenches, sockets, pliers,
and screwdrivers.
You will find most industrial suppliers such as Westward, Gray, Proto, etc. use chrome molybdenum.
Ultra Pro is primarily an automotive brand. JET tools are designed to be economical enough for
the automotive trades but tough enough for the heaviest duty user. Those selling CR-V impact
sockets probably will tell you something different. CR-V sockets are usually less expensive than
CR-MO. You should get reasonable performance from your CR-V impact sockets, but you would have
longer life with CR-MO.
I have not heard of any type of socket putting undue stress on the impact wrench. Most stress on
the wrench will be the result of over-tightening of fasteners. Whether the socket is CR-V or
CR-MO, the socket should fail before the wrench is damaged. In the case of a Magnesium series
impact wrench, I would recommend using the best quality sockets you can afford. It should be noted
there are several grades of CR-MO steel available, and JET uses the very best for it's impact
sockets.
Regards
Jeff Segal
Product Manager
and screwdrivers.
sockets.
Regards
Jeff Segal
Product Manager
