DeVoe Coatings - Anyone?
larry4406
Northern Virginia
Saw a nice floor on other website and the posting said it was DeVoe Coatings brand. Just surfed their site, and they have a 100% solids coating, DEVFLOOR521. This is a UV stable clear that can be tinted for color using their tints.
http://www.duspec.com/datasheet/dat...21&documentType=datasheet&submit=Get+Document
My recollection from the numerous Wolverine Coatings posts was that a 100% solids non-water based product was the way to go.
Anyone use this stuff? Any good?
awakeinAZ
Might be great but I wound't want to blaze a trail with floor coatings. There are enough challeneges already!
04 Navi
PNW
UV stable would definitely be a plus, especially if you go with a lighter color. Good luck.
gregs
Havent had time to put together a post about my recent floor, but I can tell you that I used the Devoe 224HS epoxy with great results. It is a 1 to 1 77% epoxy available in 2 gallon kits that I purchased thru my local ICI paint store. I plan on putting a full post together with pictures on what I used and how it turned out. I can tell you that I purchased it for $38.00 per gallon with no delivery or other charges and that they can mix it in just about any color you want. I did a little over 1400 sq ft with it.
