Can you recommend a set of super thin wrenches?
itwnexus
Can you recommend a set of super thin metric wrenches? I'm looking for an inexpensive set to hold a cordless drill shaft while I remove the broken drill chuck.
MrSnicks
Cameron, NC
I don't know how big you need, or if they would be strong enough but what about ignition wrenches?
Patrick
WHT
The forum need more information to answer your question.
What size do you need and how thin is thin?
franzdom
NC
Bicycle cone wrenches are plenty strong, I have several full sets and have wrenched super hard on all of them. Park can be had in singles for quite reasonable. If you want a full set that is better than basic I can also recommend Facom, I picked up a really nice set of thin wrenches that work great for things like stabilizer link flats.
Harvey Melvin Richards
No mention of size, but I have an adjustable wrench with thin jaws that opens to 13/16" or 22mm. I needed a thin 5/16" wrench on a regular basis. I took a cheap import wrench and hand ground and surface ground it down to the thickness that would work.
WhoWhatNow
Collegeville, PA
Davefr
OR
Make your own. Go to HF and buy the right size wrench and grind it down.
I couldn't believe how easy they are to cut or grind. (like a knife going thru warm butter)
bobemmerich
Middletown, Ct.
Try Sears. They have thin tappet wrenches that would work, provided they have your size. Can't say anything to your link, never used any of their tools.
buening
Decatur, IL
I agree with evilwelder if you have the capabilities and time. A piece of flat bar, drill bit, and a air cutoff tool (or dremel or hacksaw) and you can make your own. Undersize the opening a bit and use a file to bring it to your opening spec.
I
itwnexus
I need a 19mm or 20mm super thin wrench. I can only get a regular 19mm wrench part way in so it looks like a 19mm will fit but I might be a little larger.
I am trying to remove a Makita hammer drill Self-Tightening Chuck. It is all plastic and does not use a key.
The chuck is not stuck. It spins. The chuck does not hold the bit. If I put the drill on a vice and insert an allen key and strike it, the chuck will just spin.
http://www.bing.com/images/search?q...l&id=E803C096E2C57783203A284052834E0A5414F177
franzdom
NC
Park may not make a 19mm, if you find a 3/4" that would work as well though. That range is about out of bicycle tool size, the largest I have is 18mm. My Facom set goes to 19mm.
6-Speed
Park cone wrenches work great when you need a really thin wrench. I use the 17mm to hold the caliper guide pins on my Honda Odyssey to keep them from turning. The largest size I have is a 19mm.
altec876
MI.
How bout the hf thin wrenches there on sale for about $30 bought both sets for the amount I will use them they seem pretty good.
I
itwnexus
I search for the hf thin wrenches at the hf website. I could not find them. Please post link.
TwoInch
NW INDIANA
since the chuck is garbage, and plastic, can you bust it up to get some clearance? mount the plastic in a vise, and hit it with a dremel and a rasp or something..
from what i remember from swapping chucks, you dont really mess with the nut in there, and it wont help getting the chuck off. could be remembering wrong tho
