Electrical connector tools
l_bilyk
Ontario, Canada
I always find myself really frustrated with unplugging various electrical connectors. Can anyone suggest a good tools set that helps with these? Something other than a small screwdriver to press and release the little hooks ...
dxdexter
I would be interested in such a tool as well. Unfortunately I usually break the tabs off the connectors with the small screwdriver.
eschoendorff
That would be me. I am a master at mangling little electronic connections.
If anyone needs one of those little buggers completely destroyed, let me know. :thumbup:
Merkava_4
Clovis, CA.
I use my fingers when ever I can because I can't always feel how much force I'm applying with the pocket screwdriver.
Blacknwhitepit
Eastern Tennessee
Blacknwhitepit
Eastern Tennessee
KASTAR makes some too. (Made in USA) :)
http://www.aeincorporated.com/Kasta...lY3RyaWMmcGFnZT1zZWFyY2gmc2VhcmNoX2luPWFsbA==
I lucked out last year at this time at the flea market and bought them both for $1.00!!
-BWP
DiStOrTiOn
Clifton/Centreville, Virginia (NoVA)
I'm going to hit sears up, and find out about the lisles (where they're made), and report back. I'm leaning towards the Kastar ones anyways though, even though they're twice the price. I like the individual tool better than combo stuff.
Blacknwhitepit
Eastern Tennessee
How well do the Kastar ones work? you like 'em?
The KASTARS work pretty well, they are stout, but not too stout..If you know what I mean, You can apply pressure and still get a good "feel" for the plastic (I.E. about to snap); unlike using a screwdriver. Although they are not for all applications, they have worked well for me on larger connections.
The Lisle one (I am pretty sure it is USA made) is more flexible (all but two of the "prongs" give). It is for smaller applications and works well for the "feel" (They "give" and so does the connector). This really reduces your chances of breaking it.
-BWP
PoorOwner
CA
OK how do you use it? Do you use this to push on tabs or what?
Usually there is a place you press with your thumb and they come off right?
mulepackin
Montana
The most essential tool for these connectors (weather pack, etc), is a light touch and patience. I replaced the lift pump on my 01 Dodge Diesel last summer, and I spent more time with the electrical connectors than I did dropping the fuel tank, and replacing the fuel module.
eschoendorff
When I did that job on my Chevy, I got so pissed with the fuel tank that I ended up just taking the entire bed off teh truck! :lol: Made the job a little easier though.
Fedwrench
Valley of the sun
I have the Kastar models pictured above. They're really too long for most of the places I'm working in. I took one of the Lisle tools and cut it in half. It works pretty good. However, It's hard to beat the performance of the free tool truck pocket screwdriver when disconnecting connectors. Small 90 degree and straight picks work well also. It used to be connectors were designed to be removed 5-7 times. However, man today break after 2-3 times if not less. A narrow plastic trim tool is handy too.
Danglerb
SoCal
Amazon has the Lisle star fish thing for $8, free shipping at $25, and they have a second type similar, but I suspect slightly different sized things same price. Looks like handy stuff to have.
jay50
Agree; with all the engine heat baking the connectors, they are very brittle and will easily fall apart in your hands at times. The worst I have seen are fuel injector connectors on Dodge 3.3 engines; they require a gentle touch or they will pull apart and the guts will fly everywhere...:(
eschoendorff
So what's the consensus (from people who have actually used these things)? If someone were to buy one type, which is the most versatile and useful?
Jbullfrog
Avoca, Iowa
Get 2 of the Lisle tools and use them for plastic connector plugs only. DO NOT USE THEM TO PRY METAL! Once you ****** the tips they are useless near a plastic connector again.
mulepackin
Montana
I like the tools manufactured by Lisle for working with connectors. The pry type tool is for seperating connectors from each other, the star or spider tools are for removing or adding additional terminals from multi headed connectors such as weather paks. I have used a variety of picks, upholstery pins, and other odds and ends just about as effectively
creatureofthewheel
franklin, TN
in a pinch last week i used a piece of brass tubing stock from my modeling supplies. had a bag of scrap from k&s engineering. round tubing, square tubing, L channels, and some flat bar. i picked up the bag at hobby lobby. get a little creative.
Danglerb
SoCal
I bought the Lisle stuff, two starfish, lobster fork, and the thing that looks like a garden weeder from amazon last night, $32 shipped. I've got a LOT of wiring to mess with in my future. For the fuel injectors I got pig tailed replacements off ebay for $2 each, but lots of other stuff will have me moving pins around in old plastic.
PoorOwner
CA
Can you post the shopping list here? I have a bunch of Lisle and KD tools stuff in my cart right now I am getting confused so I want to compare! :confused:
Danglerb
SoCal
"Lisle 35260 Plastic Fastener Remover" $7.40
"Lisle 13120 Electrical Separator Connector" $7.76
"Lisle 14900 Wire Terminal Tool and Trouble Code Tool" $8.04
"Lisle 56500 Wire Term. Tool **" $8.94
Those are garden weeder, lobster fork, starfish, starfish. My understanding is that the two starfish together handle most pin duties.
PoorOwner
CA
Looks good, mine is the same .. I have gotten by with jewellers screw drivers for a while now though.
