Power your HF bead roller with a winch motor
Jim Stabe
San Diego, Ca
E-tek sent me a nice PM asking me to post a thread about how I powered my modified HF beadroller so here goes.
Before I get to the motor part there are a couple things you need to do the bead roller itseld to make it usable. The frame is too flexible vertically but especially horizontally to be able to roll steel any thicker than 20 ga and it is marginal on that. You need to reinforce the frame, I used 2" square tubing welded to the 1/2" HF frame and some additional triangulating pieces wouldn't hurt either. It needs to be stiff in both directions so that the dies stay aligned perfectly in a vertical plane and the gap between them can't expand as the frame deflects from the load.
The winch I used was the smallest 12 volt HF unit that used to go on sale all the time for $49. I noticed that HF no longer has this exact winch but has replaced it with a similar one. Not sure if all the steps I did would apply to this new winch or not. Northern Tool carries the same winch as what I used but it slightly more $$ http://www.northerntool.com/shop/tools/product_200365241_200365241 The winch comes with the same hand held controller that I used to make the foot control that allows reversing.
The winch has a handle on the end that when pulled out disengages the cable spool from the drive so you can pull cable quickly off the spool. This feature also allows you to disengage the motor so you can turn the bead roller with a steering wheel or crank.
You need to gear the motor down about 3:1 so the travel is slow enough to manage. I used 40 pitch sprockets from Surplus Center that are 15 teeth on the motor and 29 teeth on the roller shaft giving a reduction of 2:1 and it runs just a little fast and the chain size is way overkill. They sell the chain also. I'm going to recommend that you use 35 pitch chain and 26 tooth 1 1/4" bore winch sprocket and a 72 tooth 7/8" roller shaft sprocket that will give you a 2.76:1 reduction. The 7/8" bore is .009" larger than the metric 22 mm shaft and I took up the slack with shim stock but it would probably work fine if you just tightened down the set screw.
https://www.surpluscenter.com/sort.asp?keyword=PH35&catname=powerTrans&PAGELEN=20&PageNo=4
Take the winch apart and the cable spool slips off. Chuck it up in a lathe and trim off the outboard flange of the spool. You need to turn down the diameter of the spool to 1.25" so the sprocket will slip on. If you want to have the machine run even slower you can turn the spool down to 1.00" and use a 22-25 tooth sprocket with a 1" bore (I believe there is enough stock in the spool to do that but you should check before you do it).
You now need to mount the motor to your roller frame and you need some adjustment to be able to tension the chain properly. Here is how I mounted mine. Make sure where you put it you can get the sprockets to align.
After you have the sprockets aligned with each other tighten down the set screw on the winch sprocket to mark to spool. Move the sprocket out of the way and drill a hole in the spool for the set screw to go into and prevent rotation. This is what the spool and sprocket will look like.
To be able to turn the machine with a steering wheel with the motor disengaged I welded a 1/2" coupler nut to a flange and bolted it to the upper sprocket. I welded a 3/4" socket to an old steering wheel so it will slip on whenever I need it and I can turn the machine by hand. This is a nice feature when you have a sharp corner to go around or some other intricate detail to do. When you get around the corner you reengage the motor and you are back to powered operation.
It is a good idea to make a chain guard because getting anything cauget in the drive would not be good.
To run the unit I use one of the HF jump starting units that is on sale right now for $47 http://www.harborfreight.com/12-volt-jump-start-and-power-supply-38391.html
e-tek
Saskatoon, SK
Awesome - thanks Jim. The design is well-engineered and easy enough for others to copy - the hallmarks of good design!
Now to get this How To made into a "Schticky" :thumbup:
J
Jim Stabe
San Diego, Ca
An update to my original post
I was looking through the Surplus center catalog and found a less expensive option to the sprocket combination I originally suggested. If you use the 40 pitch chain instead of the 35 you can get 17 tooth with a 1 1/4" bore (p/n 1-2123-17-H @ $6) and a 48 tooth with a 5/8" bore (p/n 1-2580 @ $15.95). It will require boring the large sprocket to 22 mm but then you also have a snug fit on the roller shaft. The 35 pitch sprockets are $7 and $29.95. The chain is the same for either @ $14.99.
J
Jim Stabe
San Diego, Ca
Jim
They have a 120V winch that has a similar remote control. Is this the same winch you used but in AC?
http://www.harborfreight.com/1500-lb-capacity-120-volt-ac-electric-winch-96127.html
Dan
The controller looks exactly the same and the winch itself is very similar and would likely adapt in the same way as I described. It has the same spool disconnect feature by pulling the handle on the end. Having a plug in would be nice, although it is a lot more money you would save the cost of the jump start unit. See my update above for less expensive sprockets.
J
Jim Stabe
San Diego, Ca
I took some additional pictures this weekend with the chain guard off so you can see more of the detail. These are more recent pictures that show the truss bracing that was added. I ordered the 48 tooth 40 pitch sprocket from Surplus Center to slow the travel speed down, it should arrive this Thursday. I will have to remake the top portion of the chain guard to clear it. A while back I added a 2" post to the bottom so I can slip the machine into the corner receivers on my table.
J
Jim Stabe
San Diego, Ca
Here is an update with the larger sprocket and I also added a more convenient handwheel. With the 15 - 48 tooth sprockets it runs between 6 and 7 rpm at the rollers which is very manageable.
jonnythunder
Kimberly, WI
I really like what you did here. My only concern is weight. How much does that thing weigh? I have mine in a removable mount. I am working on beefing my roller up, and it's already pretty hefty. Great work!
J
Jim Stabe
San Diego, Ca
It's gotten pretty heavy but I can still lift it by myself (I'm 68 years old). I do have a crane I built in the shop so I don't have to anymore.
Mr.N
Mpls, MN
You need to search swagoffroad and look at troys kits to fix that set up; I want one :p
Oh yeah, I know about Swag offroad, they have you get a HF Pipe Threader @ $149
This is a winch at $85 plus a few sockets, witch I might have...
ghost68
If you're interested in making a powered tubing roller, check out this guy's YouTube videos. He did the same thing with a Princess Auto tubing roller.
Overview
Part 1
Part 2
Ghost68
kkroger
Troy did try a WARN 1.5 Winch on the tubing roller and the planetary set exploded... just not heavy enough.
J
Jim Stabe
San Diego, Ca
I have one of the HF tubing rollers and I wanted to put a slight curve in the top of the 2"x.120 wall roll bar I made. There was no way it would bend it in the stock configuration so I made some brackets to move the lower wheels further apart. It was still difficult but I was able to put the curve in it. I also had to put in some stronger grade 8 bolts to replace all the cheap Chinese set screws on the upper axle. I made the sharper bends with a regular tubing bender.
Movin/on
Brookings, Oregon
I did something similar but already had a gear reduction 120V motor. I like the reversible idea so I'll probably switch.
I didn't like the idea of reaching around the bead roller past the material so I fabbed up a differential assembly to put a steering wheel in front of the roller.
I've got a pin to release the chain drive when I'm using the motor drive.
I also converted a HF roller and besides what is pictured I welded 2X2 heavy wall sq. tube just above and below the opening on the backside. Now no flex or movement at all!
The added metal above and below the HF Bead roller was scrap yard 2X10 I beams from Single wide Mobile home trailers. I use them for all kinds of fabrication work, Frame tables
bases for stands, work benches........... Cheap and almost free. I got 100 ft. for $50
I did change the steering wheel to a Model T wooden wheel to get it closer to the roller.
The perspective is off but the steering wheel is about 2" above the working plane.
smokindawg
Great information and description as well as pictures. I was already trying to figure out what gear drive motor I needed when I found your post here.
So I joined and look forward to learning a lot as well as posting anytime I think information I have may help someone.
Thanks a lot!
