The best floor jack for the money
proudnonna
I am looking to buy my husband a decent floor jack for Christmas. He is a mechanic and works on a lot of cars, so i really need advice on the best floor jack for the money. Please keep in mind I don't have a lot of money. Thank you for your time.
P
proudnonna
I really don't want to go over $100. I would really not to go over $ 50 if thats even possible? Which ever is better? But probably American would be the better choice for us. Thank you for your time.
SMKS
USA, planet Earth
You won't get an American jack in that price range.
At those prices, your best bet will be Harbor Freight. Their jacks are all Chinese, but so are most of the other brands, unless you specifically look for USA made examples.
My next jack will probably be a HF jack, when my current Chinese Craftsman jack dies. Likely the HF units are made by one of the same companies that makes many other brands. They appear very similar to some other models sold under other brands.
bczygan
DETROIT! Arsenal of Scrappers
If he works on a lot of cars, and
some of these are trucks, you need a higher capacity jack, like a 3 ton. If this work is at a shop or a home shop, then weight might not be an issue and a steel jack will do the job. An aluminum jack is out of your price range anyway.
One choice is to keep an eye out for a used jack on CL. Might find a US made one there. But you would have to know what to look for and how to check it. You are probably better off buying a new Asian jack. Harbor Freight has a nice 3 ton steel rapid pump jack that weighs 74 pounds and coupons are available for it in all the motor sports magazines for $69.99.
Correction...I'm told the 2.5 ton is a better jack:
48Classic
Metro Atlanta
Another location to check is Northern tools I like them better that harbor freight with similar prices. The other question is low profile or standard jack. low profiles are great for smaller cars however some do not go high enough of some suvs or trucks. When looking at the jacks online look at the minimum height and the max. Good luck, your husband will always thank you for the gift...
GeorgiaHybrid
Extreme NW Georgia
One more comment. If this is for home use, make sure he has some good jack stands. Never count on the jack holding the car in the air unless you plan on collecting on his life insurance.
PDM
Coquitlam, B.C. Canada
Not to put a damper on you spirit (great when wives will spend money on tools and cars for their guy !!) but don't be too set on purchasing budget jacks unless you have purchased a really good insurance policy on hubby.
Jacks are for lifting heavy items (read cars squash human beings when they fail) so if you love your other half and need him to continue to be in your life - then I'd suggest upping your budget a bit so that you can invest in a larger stronger jack that can support 2500 - 3000 lbs. I've borrowed an "inexpensive" jack before in a pinch from friends at the track and have seen it instantaneously fail on me before dropping my racecar back down to earth with my 5 year old son not more than 10 feet away as this happened. Scared the living **** out of me (racecars can be replaced) lives cannot.
JerryC
Memphis TN
To further drive home the point made above...
I had the same jack for 20 years that worked flawlessly. I jacked up the car, set the jackstands finished the job and the jack would not lift the car off the stands. You never know when it will fail.
I bought a $50 jack to get the car off the stands and that jack failed on the third use. The Arcane I got from Costco is a much better built jack.
toolmantechie
Philadelphia
After reading all of the positive posts about the Arcan jack I bought one from Costco today for $99. The lift capacity, and low to high lifting range were major factors in my decision. I already have 4 floor jacks, but I needed something better to lift the back of the Kwik Lift ramps.
Ride_there
MN
I also bought a Arcan jack this week. I came home with a XL35, 3.5 ton low clearance high lifting jack. Should fit any vehicle I own.
When I lifted the 109 lb jack into/out of my trunk I thought I may have bought more jack than I needed. After using the jack that night to swap on my winter wheels/tires. I am very impressed. Had the length to reach the lifting points on my mustang.
It is on sale at Northern Tool
kerryt1
Oklahoma
I have the same one. Love it, do not love carrying it.
Bruce4310TX
Forth-Worth, TX
I really dont see much difference between the new style HF chinese jacks and the Arcan chinese jacks quality seems to be the same and HF price and coupons are a better deal. Any seal can fail at anytime its better to use a jack thats over rated for the job. And its funny when people like Northern tools better cause there HF tools are painted red not HF orange same stuff.
Buckaroo5
Central Ohio
I have been using the Costco Arcan jack for a year now - based on that experience, I would say that it is well worth the money....great jack.....but, I haven't torn it down.....Bruce has an opinion on construction....tell us about it....
HaroRider
New York
I like my 2 ton HF jack. Yea its chinese, but I dont care if it fails, I dont go under it when its up on the jack. My jack stands on the other hand are a different story. Only pin style jack stands for me.
SlussMan
Mississippi
I am also wanting to get this jack, I'm just not looking forward to lugging that sucker around.
liahriz
I come here from google search. I am looking for the best floor jack in 2017 (Like this site latest review). After reading all comments I have found one member suggestion to buy Powerzone 380044 3 Ton Aluminum Garage Jack. It has good rating and review.
Just I want to be sure still this model will be the best or not? Any kind suggestion or model name will be appreciated.
liahriz
Or if price is a consideration and you still want a good jack, although the made in USA claim is somewhat dubious as it appears to be assembled in the US from overseas parts.
Thanks for your suggestion. I am looking Hein-Werner features. Although price is high but I will consider it.
pbon
For the price of a Weaverjack, you could buy a set of QuickJack to lift the entire car off the ground 18 inches and an Arcan low profile 2 ton floor jack.
Commocozy
Lake Villa IL
Guys, I have a big Toyota Tundra with 35" tires and I need a jack that can lift it a decent height, most of these jacks posted here have a max lift of 18", any suggestions on a back to get the 3ton beast up a decent height? Not 100% concerned about cost, I want something safe and something that will last a lifetime.
MarkG
Elgin, IL
I have this 3.5 ton Arcan. It's fantastic, but if you need more opinions, read the 227 reviews! Gets a 4.8 out of 5 stars from 227 reviews-----that usually tells you something, or at least that's what I thought, and since buying it, I can see that I thought right. BTW----no steel was spared in building this beast----it weighs almost 100 pounds. More than 2X the capacity at less than 1/2 the price of the HW.
http://www.northerntool.com/shop/tools/product_200345429_200345429
