phenryiv1
Other than a MaxJax unit (which obviously can be put away when not in use), is there a "best" 2-post lift to install in a garage where 2 cars are parked on a daily basis? I don't have the space to install it as I see some in the threads here (very far forward), and I use my garage to park the cars in overnight, but want to add a lift (if possible) for working on one car at a time. I have (Edit): 20 deep by 23 wide (end edit) but it seems like nearly every inch is in use.
I have no issue with the MaxJax, but I am doing my homework as I prepare to purchase.
No vehicle that I have is over 4000 lb., but excess capacity is not a bad thing. I'd like to keep the cost in the same range as the MaxJax.
Thanks!
Edit: Pictures added:
The pictures above show typical daily parking arrangement. In the front of the garage are steps up into the house, and on the left side (by the Subaru) is a 4' wide area where my tool box, work bench, shelving, and a refrigerator are located. I am in the process of adding that tire rack for my out-of-season and track wheels/tires. On the right (the Acura side) is just a 2-3' wing area with overhead wood storage and a small stoarge cabinet/locker.
In the front I have a closet for the water heater, softener, and well pressure tank.
In these pictures, there is a section of drywall removed while I chased a leak in the water area. The drywall is resting on the shelving that I have on the left of the garage.
Thanks!
The price doesn't seem all that bad, either. Oh, and 110volts, not 240v! Another advantage
