Comparison of SnapOn F80 and Gearwrench Low-pro 3/8" ratchet
biggsean
Santa Clarita, Ca
Hey guys, per the request of PoorOwner, I just wanted to post up some comparison pictures between a Snap On F-80, and a Gearwrench low profile 3/8" drive ratchet. The results that I discovered were actually quite surprising. The GearWrench ratchet bears a striking resemblance to the SnapOn F80, and is even slightly lower profile than the SnapOn, as the pictures will illustrate! In terms of the drive mechanism, the GearWrench uses a 60 tooth gear, vs. the 80 tooth gear of the F80. For somebody on a budget, this GearWrench ratchet certainly appears to be a very worth option, especially in light of the fact that it comes with a full set of sockets/extensions. The SnapOn is a superior tool in terms of strength and durability I'm sure, but don't knock GearWrench for what they've been able to accomplish here!
Here is the link to my prior review of the GearWrench ratchet kit:
http://www.garagejournal.com/forum/showthread.php?t=16960
The GearWrench ratchet was $54 shipped from Amazon, and included a full set of metric sockets, and extensions.
On to the comparison pictures.
GearWrench on top:
GearWrench ratchet on the right:
PoorOwner
CA
biggsean
Santa Clarita, Ca
I'd go for the set of 4, and then purchase the 3/8" standard separately for $35. You'll have a nice comprehensive set of ratchets for only $141.
PoorOwner
CA
Since you have both.. I am sure you can tell the difference between 60 and 80 teeth, but is it a BIG difference?
biggsean
Santa Clarita, Ca
I wouldn't say it's a huge difference, but it is definitely noticeable.
If you don't want a spend a ton of money, I don't see how you could go wrong with the GearWrench offerings.
l_bilyk
Ontario, Canada
Yeah but I bet you the snap-on is going to be stronger. The way the pawls grab is a really good design... AFAIK the gearwrench uses a more conventional setup
biggsean
Santa Clarita, Ca
I have no doubt that the SnapOn is a stronger design, but for the occasional wrencher I'm sure that the GearWrench is more than enough for most people.
That said, you can't pry the dual 80 series ratchets from my hands. :p
PoorOwner
CA
I noticed the snap on is truly sealed and the gear wrench just pretends to be, on one side? A snap ring in the back like everything else, I guess so don't go dipping in cleaners now :)
sjotis
The S-O isn't truly sealed either... "DO NOT IMMERSE IN FLUIDS" is clearly legible on the coverplate.
dxdexter
The Snap-on ratchet may or may not be stronger, but under normal or intended use, I'm sure neither of then would ever break. The quoting of torque specifications achieved during testing are more of an advertising gimmick rather than an real world expectation.
On a side note: A person would have to be blind not to notice that all the Snap-on knock offs that are flooding the market of late. They shamelessly copy the over all design of the head and handle even copying the sealed head look. These copies are quite prevalent in the big box stores.
nissan_crawler
Wichita, KS
My sentiments exactly. Most of the people I see that have had "crappy" ratchets fail had a 1/4" drive ratchet with a 9/16" socket and were yanking on it, when they had all the room in the world for a 3/8".
Likewise, I'll watch people with a 3/8" ratchet and a 7/8" socket sit and yank repeatedly on a bolt, rather than picking up the 1/2" ratchet.
Common sense goes a long way.
64merc
Texas
Well said!! It's good to be reminded of this now and then.
old salvage
Rhode Island
I was in an auto parts store last week and saw a wall full of 'Duralast' ratchets. For an imported tool they werent that cheap either.
old salvage
Rhode Island
Yeah, you said it. Not bad stuff, if it were dirt cheap!!
I think they put too much effort into making the things look nice.
If i buy a tool at an auto parts store (and i have) I'm doing it out of convenience/desperation and at that point I could care less about aesthetics.
But then whats that old saying ..?... "Most lures are designed to catch fisherman not fish"
eschoendorff
From my experience with GearWrench products, i would not hesitate to buy some of their ratchets.
edit: I do not know how the "thumbs down" icon got up there... my mouse has been acting up a little lately....
Merkava_4
Clovis, CA.
I predict there will be some buy-it-now F80's for $54.95 in the future once they start getting more abundant in numbers.
