Porcelain tile goes down in my garage- finally!
Steves32
I've gone back & forth w/ flooring.
Racedeck, PVC, epoxy, tile, etc.
I work in my garage. I weld in my garage.
While I want it to look nice, I don't want to constantly worry about burns, scratches, etc.
So, tile it is.
I went with a Porcelain PEI 5 w/ a rough non slip surface.
I have expansion joints in my garage & all that looked at it- told me it was a non issue. While I have the tools & saw to install tile- my knees won't allow it. Besides, I can make more money working & paying someone else to install it.
Thought about the Schluder Ditra but many said it may cause a problem rolling a 3k lb tool box across it.
Thinset is Custom Building Products Flex Bond- allows some movement w/o cracking tiles. A special flexible cement was used to fill the expansion joints & install a fiberglass mesh embeded in the cement (this was my idea)
So- here we go.
My tile. Only 1 broken piece (I dropped the box)
That edge is aluminum made by Schluder.
Close up of edge piece. I liked the look better than the 2x12 tile edge pieces. Plus, it was cheaper!
Here, you can see the surface. Has the feeling of 600 grit sand paper. Not slick but Ez to sweep.
I've positioned the edge piece so the bottom of roll up door gasket seals agains't the aluminum ramp.
Day one. Lots of prep. Everywhere that expansion joint was tooled in when slab was wet- was raised. Had to be ground down so floor was flat.
Going with 1/8" spacers.
Close up of mesh laid into the filler cement.
Lots of grinding done here.
My tile guy is a perfectionist. It's done perfect or not at all. Perfect points & grout lines. He's slow but worth every penny. All tile laid w/ 100% thinset coverage, back buttering tiles also. No hollow tiles allowed here.
My lift is bolted to floor & staying that way by design- no plans to move it. We will cut tiles around the base.
How's this for perfection?
Full tile at front of garage
We'll have to cut 1/4" off tile at rear of garage
Working towards the back door.
Side wall.
That's it for now. He'll be back Monday to start cutting tiles.
Shocker
Olympia, WA
Looks great! Did you do a test on these with various fluids just to see what happens? I would be curious to see as they look like a pretty fancy tile.
Steves32
That's looking relly nice Where will you end up relative to a cost / sq.ft. for the tile - all-in?
Don't know. Probably double what Racedeck would have cost me
Steves32
Yes. Took 8 tiles & placed on floor. Poured antifreeze, oil (both synthetic & dino), gear oil, trans fluid, & brake fluid. Nothing happened & wiped right up- even after sitting there a week. Even w/ a film of oil on the tile- it was not slick under foot. Even used dish soap & water & not slick enough to fall.
Grout remains to be seen. But that's why I picked grey. ;)
Interex
Dallas, TX
Looks great! Not a big fan of tiles garage floor but I'm liking yours. Looking forward to seeing the final product.
Shocker
Olympia, WA
Great! Looking forward to seeing the completed installation. I would use a epoxy grout. Should be more resistant to ****.
Adam McLaughlin
Santa Rosa, CA
PEI 5 Porcelain is good stuff, this is what I did mine in.
I have been able to chip / crack the very top layer with a sheet rock hammer but other than that performance has been great with tool boxes, transmission parts, etc. etc.
Adam
Shea
California
Nice looking floor! Some of the porcelain tile floors I've seen are impressive and yours definitely qualifies . I can vouch for the epoxy grout as well. It's awesome stuff but expensive!
Steves32
If you look above at the tile picture- it's not smooth & has the feel of 600 sandpaper. That's why we are planning to go w/ a grey grout, 1/8" gaps & additive. Easier cleanup. I think epoxy grout would be a nightmare to clean off the surface of this tile.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Nice!!! I'd love to be able to do that in my garage. Maybe in the future.
If you go with a gray grout, what about spills on it? I would think in a garage you would want a dark grout to ide any spills.
But besides that, I think it looks great!!
Steves32
Are you concerned about the crack in the 8th picture? I have a few of those...
Mark
Nope. Thinset is flex bond. Suppose to allow for up to 1/16" movement. We'll see. He also rolled some Red guard membrane over that crack & one other before setting the tiles. Crack is tiny- almost looks like a pencil mark.
Note that this slab is monolithic pour w/ footers, & has 1/2" rebar on 15" centers & is 6-8" thick w/ sand & visqueen. All the cracks are shrinkage cracks. Nothing has cracked for a year now. The cracks were all in the 1st couple of months & most are in the bottom of the tooled expansion joints.
Steves32
I have 2 different colors.
Delorean Grey & Pewter
The Delorean grey & Pewter is actually darker than the pic.
I have a sample of something close to the Admiral blue too. It's a perfecrt match for my blue/grey wall paint.
ScaldedDog
Sedalia, CO/NSB, FL
Good to know, as the racks in my slab are very similar.
Mark
Steves32
FIY- Flex bond is about 3x more expensive than standard thinset.
Here's a few more pics from today.
Floor tile is almost done. Wall piece & metal edge soon.
Cuts around 4 post base plates.
At back door.
Looking good. Very pleased w/ install so far.
Elite Crete Australia
Australia
Very nice tile, the installer is doing a great job!! Excellent choice not going with Epoxy, it's not needed.
I don't know if it was an excellent choice not going with epoxy but of course, like yourself, I'm partial to my trade. Nontheless, it looks like a fantastic garage you've created, tile floor and all. :3gears:
rockchucker
Seattle WA
Nice!
All I use is Flex-Bond. I also think the Delorean Gray will look great. I use it when going over Rough Slate. It should look good and hide well.
Steves32
For those talking about using Epoxy grout......
I'm using regular grout but not mixing it with water. Mixing with this.
jweller
Your tile guy knows what he is doing. The craftsmanship shows in the layout and cuts. Very nice.
Any idea what your material costs per sq ft are?
Helios
Bellingham, WA
I keep wanting to go this route. Trying to convince myself I need to do it before I build cabinets and set up. Need to decide soon, as I want to start getting the garage user friendly.
Very nice work. :)
slickgt1
Around $4.00 a sq ft.
Excluding labor
Woa. Glad I did it myself. With mud job, mine came out to about $4, all included. Mud job cost me the most though. But cheaper than a repour.
Either way, you know that floor is for ever, and you will never need to maintain it at all.
Steves32
They worked last night till 9pm. Looks great.
He still has to come back tomorrow & clean up, do some caulking & pick up his tools.
Here's the edge piece. Slips over the edge of the tile & held in place by the thinset.
Corner. I guess I should paint the top of the stem wall now.
Close up of grout color. Not completely dry, been down 10 hours now. All same color- I don't think it will lighten any more.
e-tek
Saskatoon, SK
WOW - very professional. I do my own tile work - looks like **** compared to that..... :(
Am I the first to ask - What's on the lift???
