lilscorpion
I got a chance to play with my new set (only got standard) today for the first time. They're cooler than I thought they would be though to be fair, I was really looking forward to getting the set - I really could have used a new set of flare wrenches a month ago but I made do. As most of you would expect, they have the similar issues as the other Gear Wrenchs mfg'd in China. First glance they look good.
Closer inspection shows casting flaws visible on the jaws. Obviously not a big deal but none of my other wrenches have imperfections like this. I noticed it right out of the box and it did bother me a little. Seems it would take such a small amount of additional work to machine the affected surfaces but what do I know.
Some of the jaws aren't as tight as others. I figured out why too. It appears that the holes the rivets are in have sloppy recessing (meaning they are not all the same depth). When they set the rivet, a deeper recess allows the rivet to not be fully set. I could easily fix this by just giving them a whack. May try at some point. Had to see in this pic but the black around the head is space behind it.
The jaws of the wrench are better than I expected though not machined perfect (I know, I know).
