Doors for Shelving
sxk122
Dallas, TX
I have these...
http://www.homedepot.com/webapp/wcs...talogId=10053&cm_sp=BazVoice-_-PROFILE-_--_-x
They work well, but I've been trying to figure out a way to enclose them. It would be relatively easy to make cabinet doors, but I was trying to think of a way to add sliding doors to the front... think 3 large panels that are 36"x72" and on 3 seperate tracks so they can slide any way.
Help with Ideas?
I was thinking some kind of rail with 3 channels mounted to the top front edge of the shelving with 3 large panels of maybe luan with some kind of bearing or wheel on the bottom.
Not sure what I could make the channels out of, or if something exists. I'd like to keep this project inexpensive, sub $100-150.......... Ideas?
nine4gmc
Dallas
I think $100-150 would buy a nice used enclosed cabinet and you could sell or use that shelf somewhere else.
sxk122
Dallas, TX
sorry, I have 3 shelving units lined up. Plus, most cabinets I've seen aren't as deep as these shelves.....
Jeff Ivers
Oklahoma
If you are set on sliding doors, I would build a 2"x2" frame with cross peices where each shelf is. I would bolt the uprights to the shelving uprights. I would route a pair of 1/4" groves in the top and bottom of the cross pieces as needed. The groves on the top of each shelf opening would be about 1/2" deep and the ones on the bottom about 1/4". Then find masonite, plywood, etc that you can cut the doors from with the vertical dimension 1/4" taller than the opening. Thickness on the door material will need to be slightly less than 1/4" or adjust the groves as necessary.
Glacial_Speed
Massachusetts
Ideas to enclose the shelves??? Define enclose......I'm almost thinking like a bamboo roll up blind kind of thing instead of doors.
Maybe use some metal conduit to make shower curtain style covers....one left and one right? I guess I'm just not seeing benefits of the door style.
sxk122
Dallas, TX
Jeff Ivers, I don't know why I didn't think of something that easy.... That's EXACTLY what I envisioned, and a lot easier than I was thinking. I wonder if I could use the dry erase board material......
sxk122
Dallas, TX
Well, I went with a variation of your suggestion Jeff
Rather than going with a routered groove, I used sliding door hardware, and it is working well. Spend $25 on hardware, $60 on wood (3 sheets of Luan and 1 sheet of 15/32 plywood), $12 on trim, and $55 on a gallon of paint (DOH!).... I'll link to pictures when finished. I took it apart to paint, and I still need to install the trim. I wrapped the corner trim in foil tape, so it looks like my toolbox drawers. Makes the garage look bigger.
jlmotox
SoCal
Lets see it!! PICS!! I have a similar shelf and am curious to see what you did.
soj
North Georgia
OK, I am subscribing so I can see this, sounds like a great idea, and simple and easy to do, but I still wanna see how you did it.
jp
Jeff Ivers
Oklahoma
Glad you found the idea helpful. I, too, am anxious to see a pic or two of the finished project!
Jeff
sxk122
Dallas, TX
Still working on the trim, it is just leaned up against the cabinets. Pardon the mess. I'll take some closer pics of the track once I'm done
sxk122
Dallas, TX
old picture, but here is the shelving, the doors make it look a lot less cluttered
http://sphotos-b.**.fbcdn.net/hphotos-ash4/321673_687145034125_921192975_n.jpg
soj
North Georgia
WOW!!! Looks great. Now you have to continue the red paint/shiny trim onto the speckled workbench cabinets. It looks like the bottom of that workbench matches the floor, is it the same finish?
jp
sxk122
Dallas, TX
Yeah, the bench came from my mother in law, and I enclosed it and used a bit of gray paint from a different project on it. Threw some of my floor chips on it, and poly'd it. I actually intend to build a completwly different bench and cabinet someday (summer maybe?)
sxk122
Dallas, TX
I've actually seen your thread (they look great) and had thought about it. However, the high storage tubs are my wife's seasonal decorations, and the shelves are my tools, car care supplies, and other diy supplies. The cailings are about 10', so cabinets from 6' to 10' would require a ladder to get to anything. That said, I do have it on the "if I need more space" list for possibly doing over the garage door and spring. There's a good 2'-3' of space there.
Quickster
I've been thinking about building some basic shelving out of 2x4's permanently from one of the garage walls and out. Then adding a frame to the front of it and adding these cheap sliding closet doors to the front.. When the cars are in there would be no room for swinging doors. I figured this be cheapest/best option. I could easily squeeze in between and slide the door open to grab whatever needed.
http://www.lowes.com/pd_201611-3299...rentURL=?Ns=p_product_avg_rating|1&facetInfo=
Just haven't decided how I want to go about it yet, I spray the garage out all the time with the hose to completely rinse out the wood dust or body filler from the floor. So this will have to be up off the ground.
sxk122
Dallas, TX
Finally got the trim almost finished. Couldn't get the foil tape to work well enough on a long strip, so I ended up using metal flake paint. Here's a pic with my two helpers. I still need one more piece of trim, but it can wait.
My next project.. needs one more coat of paint on the the background, and then I can mount the logo and peel off the protection. Love having a friend with a CNC Machine!
sxk122
Dallas, TX
No, I went with 2 tracks to reduce depth. The way its organized, I really don't need 2 sections at once- tools, car care, spray paints and random ****.
