Ferrino
I'm planning to build some garage storage cabinets from 8'x4' sheets of 3/4" wood (MDF or plywood). I'm fairly new to woodwork and have thus far used my circular saw with whatever straight-edge is lying around to use as a guide (clamped to the work-piece with g-clamps).
1. I was planning to buy this Kreg contraption to help get straight cuts and avoid the whole clamping procedure. Are there any other (affordable) guides I should consider?
2. What I was wondering is what the best way to hold the large sheet is, while I cut? Is it OK to simply lay a bunch of 2x4s on the garage floor and then cut a few inches off the floor? Is this frowned upon, or is it merely considered uncomfortable? Like I said, I'm new to this, but my intuition tells me it's valuable to have some weight on the workpiece, to stop it potentially sliding around.
Thanks for any tips!
Especially good for finished plywoods, which is what is being discussed here.
I was struggling with this same problem in building a couple of workbenches. I'm a car hobbyist, not a wood working hobbyist!
My woodworking tools are rather limited.
