The Rocket Shop
woodrail
Lorain, Ohio
For the past several years, I've been making small improvements to my shop as money allowed. Various projects included special shelving, a wood floor, and improved tools!
After a "buying flurry", I reached critical mass. The result was a shop extremely cluttered that was very difficult to work in. Every project required cleanup and moving stuff around.
The shop looked like this :sad:
Sometimes the solution just gets shoved in your face. In my daily reading of "Hot Deals", a little thread about some discount Home Depot toolboxes caught my eye. Long story short: 4 base cabinets and 3 tops were soon in storage at my Moms house!
I didn't want to start a project thread right away, as it would be embarrassing to get going then stall out. It turns out I've been able to make some good progress on the shop and am about at the 75% mark. Unfortunately, the cold weather is stopping me from paint work. Hell, even the wood glue is freezing!
So, with all that said, here's my new "tech bench". It isn't made to bang engines on. It's primary use will be for precision construction of projects such as rockets, UAS (drones), electronic repair, pinball machine restoration, and model building. I has already come in handy for some very beginner rifle work. Of course the primary use is tool storage!
Over the next week, I'll be getting the lighting, power, and air plumbed. The blank areas above the bottom boxes are pull out counters. One for "dirty" work with chemicals and grease, the other for electronics, soldering, and precision assembly.
Painting will have to wait!
Mike14k
Very rural Oklahoma
In fact,
considering you're doing electronics/model work (some of which I do), I like the tilted top for a tool box and the pullouts for "dirty work". Lots of storage for small tools.
The roll-out parts bin is certainly cool.
machine_punk
Napa Valley, California
That is coming together nicely!
How do you get into the top compartments of the top boxes? Are those on slides or something?
I have found that I like to have a place to sit down while I work on technical projects...have you considered a way to get your knees under one of the benches?
Are you talking about model rockets, or more of the advanced amateur rockets? Are they RC drones?
Looks like you will be all sorted out soon.
Kev
W
woodrail
Lorain, Ohio
The top boxes will be mounted on 12" sliding bases to enable opening the top compartments, but I don't plan on accessing them much. The drawer safety latches have been removed.
The pull-out counters will let me get a stool or chair in front to let me sit down. These will extend out about 22 inches on heavy duty drawer slides. Side note, dang those slides are expensive!
I have a space exploration classroom. Everything from low-power "Estes" type rockets to level 2 high power rockets are built and prepped in the shop. I'm also starting to dabble in amateur rocketry and casting propellant.
I'm also involved in a NASA sponsored project with some specialized UAS technology. These are RC, short range & duration projects.
my58
Ventura County California
Great job!
Its great to see you are customizing it to your specific needs and wants.
I also would like to hear more about your canapy design. Is it just visual or does it also serve a unique function?
I look forward to seeing your progress.
W
woodrail
Lorain, Ohio
The canopy (I call them "clouds") were built for both form and function!
First off, I just wanted to see if I could build something like this. I enjoy a challenge!
The top cloud is attached to three walls and is strapped to the ceiling. That one wasn't too hard as weight wasn't an issue. The lower cloud is cantilevered to allow the garage door to pass overhead. It is supported by the wall and by the two steel 1 1/4" dia. EMT columns. The trick is to keep the weight low.
The clouds will house multiple small recessed LED lights to light up the counter, the band saw, and the drill press.
They are constructed from 3/16" tempered masonite, 1x3 strapping lumber, and 3/4 MDF gussets. The gussets were first glued and brad nailed to the 6" soffit and left to dry. The cloud bottom was sabersawed out and cleaned up with some sandpaper. The soffit was then bent around to fit the curve and glued and nailed in place. The strapping was added after it dried.
Please do know that I consider this an "experiment". I'm not sure how long the masonite will hold up in the temperture shifts I have in the shop. I certainly can rebuild it later with more durable materials later if needed.
The clouds still need some putty and seam work. I haven't decided if they will be white, black, or a feature color.
carbons4
Cool set up. Dont be embarassed by your "before" pictures. Years ago I worked for a company called Flight Systems Inc. that did model and sounding rockets. The company was opperated out of a 2+ car garage that was about that cluttered and packed. We put out a ton of stuff out of such a humble shop.
Really like the top work.
W
woodrail
Lorain, Ohio
Looks like the weather forecast is somewhat promising for near 50 degrees this week. If that holds true, looks like I can get some painting done.
I'm looking for some nice small recessed can lights. Any suggestions?
W
woodrail
Lorain, Ohio
After a long pause, I've managed to start wrapping up the new workbench. Here are some glamor shots to remind me what it is suppose to look like when I cover it with ****.
ksj9393
Minnesota
That is really impressive. Artwork in the garage - with functionality. I like it! Just wondering... have you done any work along those lines inside your home? I have ideas for something similar in the basement gathering area.
Grizz1963
Rochester, KENT. UK
Love your build and the details....
You may have screwed up my life now though.......:)
I am contemplating a wooden floor in my 30x30 garage too.
bj383ss
TX
This has to be the coolest workbench I have ever seen! When you get you garage finished you need to get this in one of the garage/workshop magazines. Do you have any more pics of the construction of the bench?
Bret
aggierailroad
Houston, TX
Absolutely love this! The "cloud" lighting looks professionally built!
One quick question, where did you get that chrome wrap around trim that you have on your lower bench on the side?? I have scoured the internet looking for some to finish off my vintage kegerator.
W
woodrail
Lorain, Ohio
The chrome is simply 1/2" automotive chrome body strips from AutoZone or Advance. "Cowles" I think. About $15 for 18 feet. Autozone was cheaper.
enginewizard1969
Camberley surrey UK
That's a cool workbench I'm impressed and jealous!!!. I had along with a load of other ideas to use wooden flooring still haven't made my mind up yet but its on the back burner. Just need to clear the rest of the garage then I will sort the floor.
W
woodrail
Lorain, Ohio
To answer a couple of question: The wood floor is great! I highly recommend it. Esay to sweep up, and easy to stand on. My floor was built over a old asphalt floor that was is very bad shape. 2x4's were laid on the flat and leveled. 3/4 plywood was installed over it. It is currently unfinished.
The X-1 is a great little, very simple throw together model by Pegasus. I'm responsible for a space exploration classroom in Oberlin. This will be a good, "touchable", display for the kids.
madoc1
spicewood, tx
that is great work! love the slide out counters. what is inside the slat wall enclosure? looks like a removable panel behind the band saw. storage?
W
woodrail
Lorain, Ohio
There is a full hinged, framed luan door faced with slatwall going into the storage area.
That area holds full wood sheets, misc. camping supplies, a bike, and 4 pinball machines.
It is full exposed when the garage is open.
