Garage Overhaul Using Rust Bullet for the Floor
EMC2
Georgia
Firstly my thanks to the many people who've contributed, albeit unknowingly to my project. This forum has proved immensely helpful to me. Thus far I've been mostly researching, but finally I’m glad to be able to contribute also.
My garage floor was painted many years before I bought the house with a gray paint that actually held up pretty well considering it was probably at least 12 years old. However, in the last few years it had started to suffer from hot tire pick up as shown below.
View media item 27515
View media item 27510
View media item 27509
I read hundreds of posts about different experiences with Epoxy and it seemed clear that if you diamond grind the floor and use a professional product, your results should be pretty solid.
However I was looking for a monochrome floor without the flakes and without the effort, cost and dust associated with grinding. I was also extremely risk averse and didn't want to try my luck with just any paint.
I started researching high temperature automotive paints and stumbled upon a few interesting options like POR 15 and others. The more I researched, the more I realized that there were some really good industrial options out there that had high service temperatures. I also saw a lot of posts where people were asking about using such paints, but there were no real examples of home/DIY users that had tried such products on their garage floor.
I eventually settled on Rust Bullet after reading the specifications and numerous case studies of commercial and industrial concrete applications such as warehouses where trucks and forklifts are used. (Please note that I do not now, nor ever have had any association with this product or company. I simply want to share my experience as I know others have been asking the same question.)
http://www.rustbullet.com
What caught my attention was that Rust Bullet’s temperature Service range is stated as:
"After curing, all Rust Bullet coatings have a service temperature range of 314°F (157°C) continuous, and can tolerate maximum temperatures between 617°- 662°F (325°-350°C) for up to 72 hour periods."
In theory, this should be more than adequate to protect against hot tire pickup (provided it is applied correctly). I also liked the fact that Rust Bullet did not require any acid etching
The Process:
I stripped off the existing paint using Behr Paint Stripper for concrete.
This product worked well, but you have to coat it on really thick and cover with plastic sheets to keep it from evaporating, and thus giving it more time to work on the paint. I left it on for about 4 hours before using a 3300psi pressure washer to remove.
View media item 27512
View media item 27511
I had some remaining paint where the plastic sheets overlapped or wrinkled. I went over these spots a second time with the paint stripper, to ensure all paint was removed.
View media item 27528
After 2 very thorough pressure washes to remove all the paint, I used a degreaser (Greased Lightning) followed by a soap wash and several rinses.
I then filled the cracks in the floor with concrete sealer.
I allowed the floor to dry for about 12 days at very low humidity conditions with lots of ventilation, around 70 degrees.
I then applied the Rust Bullet paint using a 3/8 inch nap Purdy roller. The paint requires a lot of stirring to mix thoroughly before use. 3 to 5 minutes, and you cannot machine mix or shake.
I used a 3M paint Respirator as advised by Rust Bullet (the fumes are EXTREMELY strong and the respirator is essential).
It is also worth noting that the paint is extremely moisture sensitive, such that even a drop of sweat falling into the can of paint can cause a reaction and negatively affect the paint.
3 gallons of paint was sufficient for two very thorough coats as required to reach the recommended DFT.
Applying the Rust Bullet is very much like painting with a deep color paint; it is very important to maintain a wet edge in order to avoid roller marks. I struggled a little with this on the first coat as I tried to figure out the correct size area to paint at a time.
The metallic look and color of the paint is really nice. A silver gray.
The down side is that any imperfections on the concrete floor surface are exaggerated in certain lighting conditions because of the reflective surface. Is this a major issue? Not for me, as there were only a few small rough patches on my floor, and my priority order list was; durability, longevity and then aesthetics.
If you have a really good finish (no patches, trowel marks, or cracks) on your concrete, this paint will give you an incredibly good looking floor.
View media item 27514View media item 27513
I kept the cars out the garage for at least 2 weeks whilst I finished the interior walls and ceiling.
For all the walls I used Behr Porch and Patio paint, to give a water resistant and washable surface. The white and gray sections were covered with 2 coats, but the red required 5 (yes that's FIVE) coats to get perfect. In the end it was well worth it as the color is exactly what I wanted.
Below you can see what the wall looked like after 2 and then 3 coats. I was getting very worried after 3 coats if it would ever turn out right. Fortunately I persisted...
After 2 coats:
View media item 27527
After 3 coats:
View media item 27526
The cars have now been in and out the garage for a couple of weeks and I've deliberately got the tires pretty hot on the Porsche to test the surface. No problems at all thus far.
The PORSCHE letters were sourced here:
http://stores.ebay.com/enthusiworks/
I’ll keep this thread updated as I guess the ultimate test will be once summer comes around, but my confidence is pretty high that the paint is going to hold up. I am really happy with the results and the many late nights were well worth it.
55cadillacking
Calgary
Well done! What a classy looking garage. Those Husky cabinets look amazing. They should feature your garage in their brochure/website. Your extensive research seems to have paid off! Enjoy.
ClickClickBoom
Indianapolis
I've used rust bullet with good results on automotive parts, and cast iron outdoor furniture. Both have been applied for more than 4 years and neither is rusted yet. Jeep floor pans (in and out), rockers, ect. The only problem i've had is that their black topcoat is supossed to be UV resistant, but It chalked after about a year in the sun.
Good product, decent price, and application is much less involved than por 15. If their floor coating holds up as well as their metal coating i suspect you'll be happy.
Garage looks great.
E
EMC2
Georgia
Post #1.... Sell Rust Bullet.... Just saying
Yes and I also sell Behr Paint stripper on the weekends, and Husky cabinets on Thursdays. :D
Actually, I understand your comment/skepticism, but the fact is; I spent a long time researching my options, and now that I'm done I wanted to share my unbiased experience.
I have nothing to do with the paint industry. You'll find me under the same username at Autogeek and Autopia forums. I'm just a regular guy (in the biometrics industry) who loves cars and detailing. Now I have a great place to enjoy both.
E
EMC2
Georgia
Thanks. I love the cabinets too. They were really easy to assemble.
Looks absolutely stunning... I hope it works out for you!
Thank you.
Stunning!
Thank you.
Very nice garage. The colors look great.
I wish my garage stuff would fit into 3 cabinets.
Thanks. I had to relocate a few items, like the lawnmower, to the basement workshop to keep things looking clean. Worked out ok.
Garage looks great.
Thanks. Interesting point about the black topcoat.
Hillbilly3
Southern Wis
WOW, your garage looks amazing! I'm lucky if I can even see the floor in my garage most days. I might have a new project next summer!
Cobra4B
Virginia Beach, VA
Fantastic... is the lower wall charcoal or a very dark blue? I assume charcoal. Where'd you get that Porsche wall sign? Something anyone can buy or did you snag it from a dealer display?
Omphaloskeptic
Ultima Ratio, Wa.
"Biometrics is the science and technology of measuring and analyzing biological data. In information technology, biometrics refers to technologies that measure and analyze human body characteristics, such as DNA, fingerprints, eye retinas and irises, voice patterns, facial patterns and hand measurements, for authentication purposes. "
I just had to look up the definition of the term to assure myself that it was not in some obtuse, obscure way associated with any aspect of the paint industry. lol
Since you have no affiliation with any of the products used in your beautiful garage, could you share with us your reasons/research for choosing the Husky products and the Behr porch paint? I'd like to know what brand of primer you used on the walls and if you think that choice may have played a part in your needing to do 5 coats of the red? One trick I've used in the past is to use a dedicated primer tinted according to the intended finish coat color in order to insure good coverage in one or at most two coats of the finish color. I myself have used Behr products over the years and have been satisfied in their application and final appearance, although if I had to do 5 coats of finish color get a good result, I doubt that I would give them a 'glowing recommendation'! :D
One final question for you, does the floor have a satin finish to it? I can't tell for sure by looking at the pic. Thanks for doing this thread (even if you work for the paint company)! :bounce:
KPSquared
Wetaskiwin, Alberta, Canada
That garage looks amazing. Keep us posted on how that floor holds up!
Your 5 coats is the reason I only use Benjamin Moore paint. . . Low quality paint like the junk that Behr puts out just don't cover.
E
EMC2
Georgia
Thank you.
Thanks. The lower wall is a dark gray color called "Sled". I'll post the code a little later when I have a chance.
Are the cabinets just stocked with detailing supplies? If so, can I see, can I see? LOL
Not quite - I kept a few other frequently used items in there :) I'm still working on filling the 3rd cabinet, but here are the other 2:
What's the Panamera like?
Absolutely love the car. I used to be a serious BMW fanatic until I got my first Panamera. Now I'm hooked on Porsche. If you have a family, (with not more than 2 kids) :) it's the ultimate balance of practicality and performance.
Thanks. I chose the Husky products mostly for their appearance, finish and also the available sizes. Another factor was that I wanted to buy in store and avoid the risk and delay of dealing with parts that may have shipping damage.It seemed a lot of brands suffer from shipping issues, and I simply wanted to be sure that if I did have a bad part, I could walk into a store and have it swapped, which is what Home Depot said they would do.
I looked at the Craftsman series (standard and professional), and whilst I really like Craftsman products I felt that their standard cabinet line did not match up to the quality of Husky, and their Pro series of cabinets just looked a little "old fashioned" for the look I was trying to achieve, due to the rounded corners on the doors.
The Behr Porch and Floor paint for the walls was based on some previous experience I had with the paint. I focused most of my research on the floor, and the one thing I really underestimated was the red wall paint. I had several coats of good white paint on the walls already, and the particular red paint color I used was not one that advised a gray primer. I was just lucky that I only painted one wall, which made 5 coats reasonably easy to apply. I would definitely not recommend this paint color/type for anything more than a feature wall. Hence my posting pictures of what it looked like after 2 and 3 coats.The gray and white areas however, covered very well with this paint (only 2 coats required), and the finish seems to be pretty water resistant.
Regarding the finish of the floor. I would call it a semi gloss metallic. I'll take some close up pics and post a little later to try and show it more clearly.
Thanks - will do.
Yes - lesson learned on the red paint. I really cant complain about the white and gray, they covered well. The red paint took about 20 x more tint in the can which I now understand is what thins the paint considerably, thus requiring so many coats. It certainly does seem like there are better paint options out there that would require less coats for red.
Modern Jess
Bay Area, California
Even with good quality paint, red can be a tough color sometimes. Two walls of my kitchen are red, and it took some doing to get it looking consistent.
BMcC
Colorado
I looked at the product information for Rust Bullet and it has every indication that its perfect for metal. I didn't see anything on there for use on concrete.
My only concern is that if it doesn't adhere to the concrete, it might start peeling and flaking. Which would totally **** for you, because your garage is a thing of beauty.
Zeke
So, one drop of sweat affects the paint. Could this then be urethane? I didn't read up on the product. Knowing the generic make up would be helpful. Thanks.
BTW, like the garage and the car.
E
EMC2
Georgia
Yes their website doesn't exactly make it obvious that it can be used for concrete. You will find info in their FAQ section on concrete applications and in the projects section. I first came across this link in Google (using keywords rust bullet concrete) after I saw Rust Bullet mentioned in a few forums:
http://www.rustbulletuk.com/pdfs/concrete_protection.pdf
Looks great, can't believe how clean that looks. great use of colour for sure.
Thanks.
Yes I subsequently found out online just how many people have had the same issue with red paint and many different brands.
Superb job, I love it :thumbup::thumbup::thumbup:
Thanks.
E
EMC2
Georgia
Great job on the garage. Looks like a Porsche showroom.
Thank you.
One word................WOW!!!!!!!!!!!!!!!!!!!!!1
Thank you.
Thanks - based on their MSDS below, it is labelled as a polyurethane.
http://rustbulletmcberns.com.au/protectivecoatings/wp-content/uploads/2010/11/Rust_Bullet_MSDS_v.R3.pdf
E
EMC2
Georgia
To help answer your question I took a couple of pics with a flash to show how the light reflects back off the metallic surface. It looks really good, but at some angles some of the imperfections in the floor are exaggerated as you can see from the second pic.
I think this is where Epoxy would have an advantage due to it's thickness, it would probably completely smooth/eliminate those issues.
DynoDave
Interesting idea. Easy to understand if you've ever gotten any of this type of product on your skin, but I'm not sure it would have occurred to me. Thanks for sharing your research.
TerryH
Springdale, AR
I love to research and I commend you for taking the time and putting in the effort to search out the right products for your particular needs. Fantasitic execution of your research. Your garage looks wonderful.
E
EMC2
Georgia
Looks amazing! one of the cleanest and nicest garages I've seen here.
Thank you.
The space looks really nice, where did you get the Porsche letters?
Thank you. I sent a PM re the Porsche letters.
Great looking garage:thumbup:
Interesting to note your comments on the red paint as I plan on using this in my garage.
Thank you. I'd definitely suggest a google search on red paint issues/problems, and you'll find a lot of nightmare stories and useful tips. Most important of all, once you've got the right primer/paint combo, is maintaining a wet edge as you go.
My pleasure.
One little known advantage to using Behr:
The guy that owns the company also owns 2 P51's, a P47 & a P38, so you helped keep those birds flying :)
Maybe for a millisecond or so :D
Thank you very much Terry :thumbup:
JimVonBaden
Northern Virginia
Great color choices and layout. Looks extremely clean. I like the semi-gloss look of the floor as well.
I like the detailed description of how you did the floor. It should help others who try it.
Jim :cool:
Ironhorse
Wow...that is Data Center Clean...very very nice...so EMC2 would not be your line of work? that would explain the clean garage..:lol_hitti
E
EMC2
Georgia
Very nice.
Thanks Zeeke.
Jim :cool:
Thanks Jim. I hope it does.
Thanks Ironhorse - I don't work for EMC2 but I certainly take the data center comparison as a compliment:) I'm in the biometrics field and our technology ends up protecting a lot of data centers. The EMC2 name is due to my love of physics.
3pedal
Brighton, CO
Great looking garage - very clean. As I am starting to think about finishing my garage/shop, I am leaning more and more this way.
I'll remember that next time I buy paint. Do you know the names of the planes and if he every brings them out?
