Who Made NAPA Wrenches?
John in OH
SE Ohio & Eastern Virginia
I recently bought a set of NAPA Professional metric wrenches off eBay, series NDRM. They are very nice, full polish, wrenches made in good ole' USA and I was wondering if anyone knows who made them?
I don't thing NAPA sells them any longer and they are kind of short in length, but otherwise they sure are nice!
petty4243
LuVerne Iowa
last I knew, Danaher was the forge
"In 1998 a metallurgist for the Danaher Corporation stated that Danaher makes all the sockets for Craftsman, Easco, Matco, Proto, Allen Wrench, NAPA, and K-D. He said all are made the same -- there is no difference between any of these sockets, in any way, except for the name. "
http://www.factsfacts.com/MyHomeRepair/wrenches.htm
Packard V8
Spokane, WA
Since you didn't post a photo, are they the same as the K-D wrenches in this thread?
I learned from these that Dahner made them for NAPA, K-D, Allen and Easco. Very nice wrenches for the money.
jack vines
petty4243
LuVerne Iowa
jack vines
must say, nice to see that made in usa at bottom of package and nice large usa on each wrench ;)
baron405
OKC, OK
I have a set of them and they were made by Danaher for Napa.
i used to work for great parts company for 5 years (company that owns napa)
danaher was the maker for the entire NHT (napa hand tools) line since late 90's... they just changed over to CarlYle (www.carlyletools.com) for commission reasons if i understood correctly. this happened mid 2012. both are great brands and have low failure rate.
J
John in OH
jack vines
Yeah, I should have posted a photo originally, but since I didn't then, I will now. And, yes, these NAPA wrenches sure look a lot like the KD's in Packard V8's photo. Replace the size fractions with metric sizes and replace the "KD" with "NAPA PROFESSIONAL" and it appears they are the same. The "U.S.A." appears identical.
lbgradwell
Oakville, ON
Much of this original 1998 post (it was much longer) was accurate, but there are some glaring errors too.
Firstly, it should be obvious that Proto would not be part of this group!!!
And, equally obvious, there are clear differences between those other Danaher-produced brands apart from the stamped name! And that's just the appearance...
kc-steve
Kansas City
New Britain's model number I think, but NAPA was also good about using the same model # for different manufacturers. New Britain was bought by Stanley in the 1980s . . . so unless we see some photos it is just a guess for anyone to say who made them.
Steve
jmm
NC
Many years ago they used to make raised panel Napa wrenches down the road from me in Gastonia, NC at the Easco facility. This area is full of factory seconds (lots of first quality stuff, too for that matter) marked Easco, Craftsman, Napa, etc. Not sure if they did the full polish Napa wrenches. However, I do quite often see satin-finished non-raised panel Napa wrenches around here all the time. A possibility.
petty4243
LuVerne Iowa
I did not proof read, was a direct quote from link I posted.... and quickest sorce of info i found... had known they did napa easco and craftsman myself as well as others.... curiousity killing me now though, who did make the proto wrenches and where?
Packard V8
Spokane, WA
The pre-full-polish Easco wrenches are identical to the raised panel Craftsman. Obviously from the same forging die.
jack vines
