Small UK workshop in Surrey BIG PLANS!!
enginewizard1969
Camberley surrey UK
Hi I have only been on here for a short while and looking at some of the garages on here Im impressed :eyecrazy:. I keep changing my garage around as I am never happy with it!!:dunno: Now I have seen what some of you have done with the space so I have drawn up a plan!. About 6 years ago I had an extension built on the side of the house did put in for a double garage with two bedrooms on top but the plans got rejected and I had to fight to make the garage a little bigger. I am going to put a carport on the side of the house to store the cars and use the garage as a workshop / store.
Can't seem to find any pictures of the garage before it was knocked down and the new one built. When I do find some I will post them so you can see how small it was. Here are a couple of pictures of what it looks like at the moment believe it or not I have just had a major sort out and can walk from one end to the other without having to climb over things.
from the main door
from the other end
The plan is to double the length of the workbench and make some wall shelves above it, add a lot more lighting including fitting lights to the bottom of the shelving so the workbench is brighter. Also fix the shelving unit at back to the wall so it doesn't move Im just waiting until I hear the unit fall as whenever I put something on it it leans even more. Once all that is done I will plasterboard the walls and paint them might even do a two tone colour scheme. I did see someone had used red duct tape to make a border which looked good. Then it will just leave the floor, I painted it red when the garage was first built but it needs doing again. I do like the floor tiles that some people have used but over here they are quite expensive. Thats it for now not going to do anything tonight now but the big change will start tomorrow.
GBsnoopy
Durham, U.K.
Looking forward to following your progress. I know how long it takes to sort through a place like this.
lmb
United Kingdom
Sounds like a good plan. You may find it is not worth the bother of plasterboarding the walls - have a look around at other garages on here as a lot of them look good with just painted brick/blockwork. Plasterboard becomes a good idea if you are adding an insulating layer behind, so it depends on whether you are intending to try and keep your garage warm as to whether it is worth the extra work/expense I guess.
GBsnoopy
Durham, U.K.
Exactly some of the best garages I've seen in the UK on here and detailingworld etc only have painted block work. That's what I have planned for my new build.
Plaster boarding makes it harder to change locations of things and unless you have a stick build or want to go for a show smooth finish or for insulation reasons I think its overkill.
I also plan to paint (mainly to seal) the walls on my attached garage then cover the side walls in slat board /wall (what shops use to hang things on) so I can change the way I hang tools when i change my mind on there layout, maybe that would be a cheaper option if you want a show finish.
E
enginewizard1969
Camberley surrey UK
It took me about a week to sort it out to how it is now. I still had a large plastic box that I was given full nuts bolts and clips to sort so I can find what I have when I need it.
I have painted most of the walls already I was only going to cover the walls as when they took the my old garage down I have a row of stepped bricks holes which I was going to hide. But you lot are right and as I do change my mind I think a new coat of paint is in hand and to fill the holes in the wall . As my wife keeps saying to me its not a showroom its a working garage.
lmb
United Kingdom
Apart from your time and about £20 for a ten litre tub of white paint you've got nothing much to lose - if it isn't up to your standards once done then you can still stick the plasterboard over the top of it then ;)
Bib Overalls
Jonesboro, Arkansas
Here in the States drywall (plaster board) is attached to masonry over wood or metal strapping. About 1.5 inches total thickness. Does not sound like much, just 3 inches out of the floor width but in organizing a small shop every bit of space is precious. I would not trade the space for smooth walls. I would make such a trade if the benefit was a warmer, insulated work space. Those are my values. Yours may vary.
E
enginewizard1969
Camberley surrey UK
had a good day on the workshop today. Well a good afternoon after the wife had me running around getting the food shopping then getting rid of some rubbish at the local council dump. Then I could start
first job was to empty the garage of bikes, boxes and car bits
Firstly I wanted to double the size of my workbench by cutting a shelving unit in half and putting it on each side of the original. I moved one of my toolboxes and built it into the workbench. this had two benifits 1 gave me more room and raised the box up to make it easier to get into it. 2 I help restore army vehicles and used to wheel this box up a ramp into the back of my car after a while the weld broke and it all went floppy this now holds it in place.
Next job is to make the shelf unit that will screw to the wall and hang from the ceiling
this is what holes I wanted to cover up by covering the walls with plaster board (dry wall) I am going to cover them with a board and then repaint the walls.
Also with the longer workbench I could move the computer that was perched on the end of my rollcab now I can use the mouse and keyboard without having to hold it.
this freed up the end of the rollcab to make a charging station
this is the area to the side of my garage where I am planing to build a carport and might even at a later date put ends on it (and yes there is a car under all of that lot!!!)
HSpencer
South Central US
Looking a good bit better with the reorg. Your over bench shelves plan will also help a whole lot. Keep the thread going. It looks quite shop like now. Also interested in your plans to utilize the side yard you show.
Cheers
E
enginewizard1969
Camberley surrey UK
the plan for the side yard is to clear all the rubbish. I have just had a quote to build a carport the full lenght of the garage. once that is done the plan is to make ends to enclose the back end near the shed at the end, I will make a gate at the end near the shed so I still have access to the shed then put a door on the front to fully enclose it. The carport will have a clear roof to it for extra light. Hope to build the shelves above the workbench this week after work and get them fitted at the weekend. I have noticed that some of you have added storage above and to the sides of your main door which I think I will do as well. Now need to go to the local hardware shop and look at lights for above the workbenches and would like something near the main door as well. Must go and do somethings around the house tonight so I can play at the weekend!!!
E
enginewizard1969
Camberley surrey UK
Hi
I got a few of them now. I used to go to Florida each year and go to a place called old town to see the car cruise on a friday and Saturday evening. Now I have to get them in the uk now as I have 3 kids (or as better known a drains on my wallet or more importantly my car fund!!) so Im having to save up my pennies before I come back over to your side of the pond.
E
enginewizard1969
Camberley surrey UK
Small update. sorry no pictures as it was dark outside by the time I finished
Wanted to get out for the whole day today but after letting the kids have a sleepover at the in-laws I had a long lie-in!!. Then the wife had me doing a bit of housework. So it was 3.30 before I got out into my workshop:willy_nil I wanted to make and fix the shelf unit above my workbench, Instead I got side tracked and made a unit on the other side of my rollcab. At the bottom I have put my compressor which when I get time I will make a vented cupboard to make it run quiter. Also now i have room for my tools that dont fit in my toolbox. Then I set about making the shelves for above my work bench which I have finished making them but haven't got it on the wall yet as I ran out of time. I won't be able to get out tomorrow as its mothers day so a day out is planned (might get up early and have a play won't be able to fit the shelf unit up as it will be to noisey :sad: )
will get some pictures next week once the unit it up
intil next time
E
enginewizard1969
Camberley surrey UK
Been out for the last couple of evenings :thumbup: First thing was to clear the **** off the workbench then had to be creative as I was working on my own and had to get the shelf unit I had made at the weekend on the wall so I could mark it ready to drill then to hold it up whilst I screwed it up
amazing what a few bricks wood and some old paint cans can do. Only problem was when I came to take it down I dropped the wood and it wiped my cup out luckly I had finished it shame I lost my favorite cup
This is it now fitted wont put anything on it at the moment until it make some straps to fix on the front bkts (will have to do that at the weekend due to the noise)
nice and level
Found this clock whilst I was on a weekend away with the family looked cool so I had to have it
and with a flick of a switch
that it for now hope to be out again at the weekend
E
enginewizard1969
Camberley surrey UK
was allowed out to play today :thumbup: My son also came out to help Finished the straps for the shelves and got the all bolted in then sorted out the bench
also sorted out my storage shelves
sorry about the pictures I used my sons ipod
happy with that now :beer: Also added an extra shelf started to clear the floor but its taking longer that I thought didn't know how much rubbish I had in there!!! hope to have most of it sorted by next weekend
Also I have now planned what lighting I'm going to have just need to go shopping now
GBsnoopy
Durham, U.K.
Don't worry my workshop garage has took me over a year of saturdays to tidy, sort through and organise with many many trips to the tip per weekend. It takes far longer than people think.
E
enginewizard1969
Camberley surrey UK
have had a couple of evenings out in the garage clearing my workbenches and tool boxes
from this
to this
also hung my garage art back on the walls
also went down to my local hardware shop and found some led kitchen under cupboard lighting units which fitted nicely
now the garage is getting there. looking a lot better:rocker:
also started to sort my tool box didn't know I had so many sockets my main toolbox
and still to be sorted
thats it for now, going to have to leave the garage for now as I need to crack on with my project car. Still be on here though
E
enginewizard1969
Camberley surrey UK
haven't been out in my garage for a little while. Put my hand to a bit of woodwork today wife has wanted a pergola over the decking. Thought I better carry on with it as I did start it last year (well I cut the 6 post and fixed 1 in!!) now I have extended one corner of the decking where we had a flower/ weed bed, Fix up the rest of the posts. Now my wife being my wife didn't like the pergola kits that you can buy also the size of the decking doesn't seem to be a standard size so I and to buy the wood and cut the end that she liked. I got the front and back ends cut and started to make the top beams 4 down 8 to go!!!, also I wanted to fit the jockey wheel on my trailer finally got the wheel fitted after darting in and out of the rain slowly getting the jobs off her list done so I can get back out to my garage and my cars!!!
E
enginewizard1969
Camberley surrey UK
I back out again!!!:thumbup:
After spending a couple of weekends in and out of the rain I got my pergola finished
still got some more to do as the wife wants a corner seat made for the decking just waiting for the wood to arrive
had to get most things out of the garage so I could sweep it out again amazing where all the sawdust ends up
I have spyed out some cabinets to replace the shelves at the back of the workshop so it should look a bit neater fingers crossed I can get my hands on them.
looking at the floor again I think for now I'm going to paint it again.
next to sort out is my extra parts shelf over the last few year I have just been stuffing bits on the shevles now it just looks a mess.
As the weather was good last weekend I got my latest project uncovered my 1984 Simitar GTC. Got this car a few years ago in boxes the car had been completely stripped apart from spilting the body off the chassis. I got it thinking I could get it repainted and rebuilt within 6 months that must of been about 3-4 years ago amazing what gets in the way!!!
hope to get it off to the bodyshop for paint by the end of July (but I not making any promises knowing what the British weathers like)
E
enginewizard1969
Camberley surrey UK
just celebrated fathers day. My son made me proud. As a present he designed and printed a mug (was a project he did for school) the car is my Burlington that I built
also spent a little time sorting out my sockets until I ran out of clips which gives me an excuse to go tool shopping!!!:3gears::3gears:
E
enginewizard1969
Camberley surrey UK
looking good, definitely a tight fit!
yes it is,
but well used area with lots of storage,
When I get a little more free cash I want first to build a carport on the side to store and work on my projects, then enclose it to make a garage for the cars. this will never be a show garage.!!!
Next part of the project is to do something with the floor (I have some commercial floor tiles or just paint the floor again)
Also I was looking to get some cupboards for the end wall to replace the racking but thinking about it I might just get some matching plastic boxes to replace the tatty cardboard boxes.
I would like to end up with a neat but practical work space.
HSpencer
South Central US
Super job on the pergola. Your shop is very nice and can be organized nicely with the cabinets your wanting. You place looks great. I will be watching for that shop organization and I know it will be great!!
Best Regards
Herb Spencer
Ryf
Southern Ohio
I am doing that exact thing, I had a carport roof put up and I'm closing it in, I do light fab work in a small single attached currently, was sitting inside my new area (still working on closing it in) and wondering what the hell I'm gonna do once i'm not tripping over everything!
Thruxton
Virginia
Coming along well! Work goes so much faster when things are organized. I had to look up Burlington - interesting history! Do you still have the car?
battymatty
Port Talbot, Wales
Nice to see a project going on in this country :) looking good there, amazing what a clear up can do to transform a space. Keep the updates coming :)
E
enginewizard1969
Camberley surrey UK
yes still have it. I have two of them. I have to rent two garages to keep them in. I also run the owners club which I started when I pick up the plans. The first club closed down. I was amazed how many Burlingtons are around, especially as most were sold as plans so they were easier to post all around the world
I use it to do local car show and charity runs:3gears:, I enjoy raising money for good charities (you can never do too much for a charity!!) and showing my car off is an added bonus
E
enginewizard1969
Camberley surrey UK
just re-drawing my plans again I told you I can't leave my work space alone for long. The cabinets idea will has been shelved. going to extend my workbench to the end of the garage as behind the storage shelves are more power sockets the going to make unit for my table saw that will be part of the workbench but put it on wheels so for larger project's I can move out. The shelving units will be cut down and moved to the side. Hope to start this phase over the next few weekends
E
enginewizard1969
Camberley surrey UK
Saturday after work and running around after the kids :willy_nil I started on the last remodel of the garage. First was to remove most of the bits off the back shelves and parts rack.
didn't know how much I had in there!!!!
when I moved the corner unit I found I did have a work buddy!!!
soon had that cleared out now have extended the work bench too the end had to cut a hole in the end of the bench to make room for the water pipes. Once I clear the floor a bit I will post some more pictures. next job is to paint the end wall and make my table saw trolley and find room for all the bits
G20-Budo
Chandler, AZ
Looks like a great project. The pergola looks great! I'd like to build or buy one like that some day for my back yard. I also know what it's like to find a ton of stuff, and realize "wow I've got a lot of stuff!". I'm going through that right now.
E
enginewizard1969
Camberley surrey UK
I couldn't find a kit that the wife liked and to the size of the decking that I had ended up designing an end that she liked bought a load of treated wood beams and set about cutting each end and notching them together. I also cost a fraction of the price of the kits.
G20-Budo
Chandler, AZ
Wow.. great job! I'd like to get some info on how you did that. I would love to have one of those in my backyard off the end of the patio.
E
enginewizard1969
Camberley surrey UK
Had a good play at the weekend had a sort out of all my bits and pieces. now I think its starting to get where I like it. Still goto to paint the walls. I put the wall art up so it wouldn't get damaged.
this is what the end wall looks like now
hope you can see the pictures at I am tryingout the thumbnail way of doing it
I have found some wheels to make a mobile table saw so if I have a larger project I can wheel it out.
also scored at the weekend :beer: a neighbour popped round over the weekend and offered me a toolbox
was going to decline as I thought it was just the toolbox as you can see its a bit knacked but it came with all the tools which are mainly draper and halfords pro makes
E
enginewizard1969
Camberley surrey UK
Hadn't had too much to report recently. had a few days off work so thought I would crack on!!!
completely finished the deck area so I thought :lol:
had to make a table someone offered me the table frame for free as her son had smashed the glass when having a party!!! getting a new sheet of glass outweighed the cost of a new table so I reversed some decking boards one table
then made a corner unit for the seat and a stand for the BBQ. The wife the found some cushions
Then I had to go to my mums to sort though her garage and collect the last of my late dads tools
now just got to sort though them the blue box on the bottom is just full of spanners!!
also got another vice
today I have started clearing down the side I have a couple of builders how are coming around this week to quote for making my carport this is stage one what I want to do later is remove the fence and enclose it completey to make another garage. At long last its starting to move!!
also my GTC has finaily gone off to the bodyshop to get its new shiney coat of paint. everything seems to be happening at the moment long may it continue :lol::lol::lol:
E
enginewizard1969
Camberley surrey UK
builder has been!!!! hope to start in the next few weeks on the carport. He is hoping to bring a group of guys and get it built in a couple of days lets hope it goes as planned
