Hi Guys,
I have a double car garage (door is 7' tall, made up of 4 21" high sections) with a "Overhead Door" screw drive opener. The problem is that the rails are 7' 3" high and I am wanting to put a 4 post lift in there to stack two cars. My actual ceiling is 11' high but the gotcha is that I have a support beam that runs side to side across the whole garage. Its lowest point is 9' 8" above the floor. The beam's front face (closest side to the driveway) is 7' 7.5" from the inside face of the wooden garage door frame. Because my garage is so shallow, the lift will be close to the door frame. This means that the door will have to go as straight up as possible and then back... it's not so much that it needs to hug the ceiling, I just can't have it any lower than the 9' 8" beam (including the opener, rail, etc.). 9' 8" *just* barely gives me the minimum clearance to stack my two cars with the Revolution lift.
I had the guys from "Overhead Door" come out and they said that the opener would have to hang down below the beam because of the extra segment(s) they would be adding to the door and how it would still require the door opener to be as far back as it currently is. Then he said I could do it with a manual door and no opener because that door would be able to go up more, then back, and yet not require the extra segment(s). Then after he left I spoke to him again and he mentioned some kind of "side jack" opener that would mount to the side and possibly allow the door to be up in that pocket, but he wasn't sure exactly if it would work, etc. It's been a painful week of waiting for a response and so I'm trying to do some research on my own. Given the dimensions I listed, is this situation do-able? I'm willing to get another door if that's what it takes, but I have to have an automatic opener (telling the wife that I traded her garage door opener for my lift is not going to make for a pleasant situation
I've attached a few pictures to help show what I'm talking about. I've seen some other high-lift discussions on here, but didn't see anybody else that had this stupid support beam in their way. *Hopefully* there is a way to make this happen!!
Thanks,
Jeff
)I've attached a few pictures to help show what I'm talking about. I've seen some other high-lift discussions on here, but didn't see anybody else that had this stupid support beam in their way. *Hopefully* there is a way to make this happen!!
Thanks,
Jeff
The only way to use an operator with one is a comm. jackshaft operator which isn't very safe and they do not warranty them for resid. use.
