Swivel VS. Fixed Casters
vlpronj
Wharton State Forest, NJ
Not that I've lost sleep over it, but I like the method of fixed on one end, swivel on the other - it lets you swing the item into a spot like parallel parking.
kbs2244
I prefer a swivel at each corner
I have some top heavy stuff, but no tipping problems.
Cryptic1911
Willimantic, CT
I hate straight casters.. Our toolbox has 6 wheels, 4 of which swivel, and it's a ***** to get it maneuvered into anywhere tight because of those two stupid fixed casters
Kevin54
MEMBER EMERITUS
Urbana, Ohio
For my toolboxes, I would rather have 4 swivels. With that, you can shove the box in between things. With two fixed casters I find myself having to see-saw the box into a spot to get it against the wall without damaging either the box or wall.
smschriefer
Yorktown, VA
I've seen them elsewhere, but I learned of them in the military. We used those on AGE equipment on the flightline. It was the best of both worlds and in some ways it was better. You can lock one wheel perpendicular to the others and that item is a pain to move.
rharman
SoCal
Four swivels. The ONLY way to go. Like Kevin said, you can park it anywhere.
Hardline4
I prefer TSC or HF. HF has sales often you just have to be careful and use your brain when buying. You can tell the quality just from putting them in your hand. Stay away from the plastic types HF sells. Even though they list some of them as rated for several hundred pounds they are junk.
454ragtop
Carver, MA
Yep, just cut the 2 fixed wheels off my HF 1 ton folding engine stand, and replaced with 2 more casters. Much better. Cool thing was, I didn't like the caster wheels, so replaced the wheels in the casters with the fixed wheels I cut off.
metalmagpie
Seattle
If you take real casters to a real caster store, they can sell you the swivel locks and/or brakes that fit your casters. If you use $1.99 junk from Harbor Freight you get to drool and dream.
The older I get the bigger the casters I use on my projects.
metalmagpie
NUTTSGT
Northern Central Ohio
I'd prefer have 2 of each, especially if I'm moving something over a longer distance and trying to go straight.
If I was going a short distance and needed some manuverabilty, I'd probably be happy with 4 swivels.
If I had to pick one, I'd take 2 of each.
