TerryH
I had debated about getting a horizontal band saw or a dry cut saw for cutting tubing, angle and the like in my shop. I decided that I would go with the dry cut saw for a variety of reasons including the cost and the small foot print of the dry cut saws. I'm a wood worker and the dry cut saw was a much more familiar platform for me to work with vs the horizontal band saw as well. After looking at the Rage saws and several others, I decided to go with the Northern Tool 14" saw for $279.99 with free shipping. The saw comes with a 2 year warranty.
Seems that there has been quite a bit of interest in these saws of late so I thought I'd post a mini-review and my initial impressions.
Here is the link to the NT website...
Norhtern Tool 14" Dry Cut Saw
The saw arrived packaged very well and undamaged. NT uses a heavy cardboard box with custom fit styrofoam inserts to hold the saw.
I checked the saw for setup and it was dead on 90 degrees right out of the box.
The saw is very similar to a abrasive chop saw but it turns only 1300 rpm vs the closer to 4000 rpm of an abrasive saw.
The all metal blade guard covers the entire blade until you begin to move the saw into the work. The blade is a 72 tooth metal blade with carbide teeth.
The hinge mechanism and the table are very similar to a quality chop saw. The saw also has a quick release clamp on the fence screw which is nice.
The base is a cast metal I assume it's aluminum. It is not magnetic anyway even though the NT website lists the base as "steel." I had assumed that it was stamped steel but it is obviously cast.
I made some initial cuts just to see how it would do with 2x2x1/4" angle. The cuts are very smooth and completely burr free. I'm impressed all the way around. The saw is not nearly as loud as one would think a metal blade cutting metal would be.
Here is the cut quality on the angle...
The saw has a chip collection tray under the blade. It is secured with a wing bolt on the rear of the saw. I'd say that 50% of the chips go in the tray and 50% go everywhere else. I'll be making some sort of tray to help capture the chips a little better once I complete the bench that the saw will be used on.
The saw has a chip deflector that is adjustable to help guide as many chips as possible into the tray.
This is not my video. I found it while I was researching the saw. I thought I'd post it here since this guy does a great job of showing how easily this saw makes a cut.
YouTube video of the saw in action.
All in all I am more than pleased with the saw and it is certainly on my recommended tool list. It seems very well built and the overall quality is very good. It was a completely pain free transaction with NT also. It was my first purchase from them but it will likely not be my last. Thanks for looking. Hope this helps someone.
Terry
Terry
Right now I have the nice Ridgid 14" abrasive and a Milwaukee port a band. If I can use the band I do.
