Kevin54
MEMBER EMERITUS
For ****'s and giggles, I pulled my truck into the 24' deep side of my garage to see if it would fit. I know that since the weather is starting to warm up that some are going to dive into the new garage waters, and over the last month or so, there has been some discussion on garage depth. My other side of the garage is 28' deep, but this side is only 24' because I have a 4' deep closet.
I was working on my tractor today on the deep side, so I wanted to pull my truck in on the short side to see if it would fit. It does, but barely, with my desk up front. If I had a bench all the way across I would literally have 12" clearance in the front and 4" behind the truck. A tight fit for sure.
So for anyone deciding to build a garage, and only going 24' deep, you may want to reconsider and go AT LEAST 4' more t 28' minimum for depth. On my 28' side, I have my air compressor up front, plus two roller cabinets, and have all sorts of room to walk around the front of the truck, plus squeeze behind the truck. Once I have it over there, I'll post pics of what 4' of extra depth gets you.
So anyways, since I was trying it on for size and the truck was there, I thought I'd post pics up of what a full-size 4 door truck gets you as far as room in the garage.
