I ordered two Brunnhoelzl jacks (one for at home, and one for the road)
The road-duty jack is the Warrior Jack in Emerald Green (to match my track car) and the home-duty jack is the Low Profile Jack in Snap-On Extreme Green to match my tool chest.
I figured since there is not much info at all about these jacks on the internet, I'd post some pictures and some measurements comparing the two.
The first thing to notice is that the Low Profile Jack is space framed and has more detailed machine work for weight savings. The cross-beams also have an hour-glass turned profile. The handle receiver on the Warrior Jack is a rough casting whereas the one on the Low Profile Jack is nicely finished and machined.
Here is a shot of the two jacks being compared at minimum saddle height:
The minimum height of the Warrior Jack is an even 3.43" across the saddle. The minimum height of the Low Profile Jack is 2.33" at the front edge and 2.67" at the rear edge.
The maximum saddle height of the two jacks are quite similar, with the Warrior Jack coming in at 17.5" and the Low Profile Jack coming in at 17.44"
Impressively, the Low Profile Jack is a full 2 lbs lighter than the Warrior Jack. The Low Profile Jack weighs in at 32.6 lbs and the Warrior Jack weighs in at 34.6 lbs.
Some action shots of each being put to the test below:
Let me know if you guys want any more details about these.
