DIY File Handles Without a Lathe.
lilredex
Toronto
One of my favorite "free wood" locations had some mahogany (looking) sticks today, so I grabbed a few. They came in various colours and weights, and were part of some crating, probably originating in a country like Indonesia.
My project was file handles, using only a plane, rasp, and sandpaper. The ferrule is a length of steel tubing, from a chair leg, and was pressed on. The finish is wiped on boiled linseed oil. The octagonal shape helps to keep files from rolling off a work table. The taper helps to make a custom fit for your hand.
Brad54
Damn, the flats on the sides are a GREAT idea! One worth doing on my existing file handles.
-Brad
ADSR
Great idea! Much better than the plastic oil product stuff people love so much.
skippy24
Reno, NV
Nice job. How did you account for the tapered metal file insertion? Did you just drill a small hole in the wood handle?
L
lilredex
Toronto
Thanks.....Step drilling (three sizes of bits) is the preferred method. If you just bore one size equal to the midpoint dimension of the tang, that works too, on the smaller sized files.
Have used both methods sucessfully.
MarkG
Elgin, IL
Nice. I did something similar years ago, but started with an old ax handle or something, and filed and sanded the end to shape and varnished it. It's got an oval shape that keeps it from rolling, I did the stepped-drill hole for the tang as you did, but made my 'ferrule' out of tightly wrapped bare wire wrapped into a shallow groove filed on the handle to kind of keep it flush and neat, as shown. I wrapped it into a thin smear of epoxy to keep it in place. The wire wrap also ensures that the handle won't split when the file is jammed in there tight!
Bugeyed Earl
Davie, Florida
Nice work on the handles! I love finding interesting exotic wood in pallets. I usually can't identify it, but it's nice to work with.
I usually use wine corks for my file handles (the synthetic cork/rubber ones hold up best.) Due to the size, they serve more to keep from getting jabbed by the pointy end of the file, but that's adequate for me. And I get to drink wine.
L
lilredex
Toronto
Thanks, you never know what turns up in pallets and crating wood.........kind of like living on the coast and watching logs drift in...could be from anywhere in the world.
Jere
My favorite is the broom handled one, just my style. Nice work on the others, they came out very well and I love stuff made from pallets
