Scotch-Brite wheel for bench grinder
EOC_Jason
Bentonville, AR
Basically yes... Other words you might want to search for are:
"Polishing Wheel" and "Fiber Wheel"
It really depends on the density that you want. They wear kind of fast and you have to be careful with the more dense ones because it will grind away material like a stone if you aren't careful.
I prefer the regular wire wheel for rust removal. Once you get the rust off I wipe it down clean then go again on the wire wheel to polish it up some more. If I want a high shine that's what a buffing wheel is for with either black or white buffing compound.
EOC_Jason
Bentonville, AR
I'm assuming these won't rip stuff out of your hands like a wire wheel?
Well... It depends on how you hold something... Think soft / spongy stone wheel... Though if you really get on it with these wheels, not only will it eat away material fast, it will wear away the wheel fast too...
Patrick Boyle
Western Montana
EOC_Jason
Bentonville, AR
True. Now I'm curious, can they get into threads and such?
I use the WW alot to remove teflon tape, etc.
Not the ones I've used... But they will grind down those threads in a hurry for ya...
I've got time, let me go take some pictures and a video so you can better see what I'm talking about...
lilredex
Toronto
Not a bench grinder wheel, but CTC has these on sale for $12 regularly. Have requested they sell them separately....without sucess. Also suggested PAL carry them.
They are much better than a wire wheel and strip off rust and mill slag (hot rolled steel) really easily with no damage.
http://www.canadiantire.ca/AST/brow...ng+Disc+Set.jsp?locale=en#tab_page_reviews_li
All the steel was hot rolled and really rusty, on the shear mount here.....cleaned up like new with one of those wheels.
http://garagejournal.com/forum/showthread.php?p=3153303#post3153303
WWIIjeep
Arizona
Nowhere near as easily. They'll still grab stuff if you're not careful, but if you rate wire wheels as a 10 on the rip-out-of-your-hands scale, 3M convolute wheels rate about 3, except for very small parts that are nearly impossible to find on the floor, halfway across the room. The wheels just know to grab those. :lol:
Better yet, they won't give you anywhere near the "road rash" a wire wheel will if your fingers accidentally brush up against the wheel.
Which type are you using that wear kind of fast?
I'm asking because I've had exactly the opposite experience with the 3M EXL-series convolute deburring/polishing wheels.
This one his been in use for 6 years, and it's been used a LOT:
If you use them for snagging and deburring they'll wear faster, but for rust removal and polishing, they'll outlast wire wheels 10 to 1 in my experience. The one in the photo has only lost 1/8" in diameter in 6 years of use. By comparison, the fine 6" wire wheel on the other side is just about worn out and hasn't been used anywhere near as much as the 3M wheel.
More importantly, they're far better balanced than the current crop of wire wheels are (far less vibration), they don't throw shrapnel at you, and as noted above, they're far less likely to grab parts out of your hands or bark your fingers.
Their disadvantage is that they're not flexible, so they won't fit into tight convex curves or polish rough finishes (like cleaning rust out of knurling or pebble finishes and so on). They'll also remove sharp edges, which is both an advantage and a disadvantage, depending on what you're using them on.
I've got that 1/2" wide x 6" diameter wheel and on another buffer, I've got 1" and 2" wide x 8" diameter wheels for heavier use. I hardly ever use wire wheels anymore except where the convolute wheels won't fit, or to blend a finish (with a fine wire wheel).
The 1/2" x 6" one pictured above is this one:
http://www.grainger.com/Grainger/3M-Convolute-Wheel-4ZR80?Pid=search
At $71.40 it may not seem cheap, but considering how much better and longer-lasting it is than a wire wheel, it's well worth the price IMO. I'd include a McMaster link for the same, but I don't think they carry that size.
For finer polishing I use this:
It's a rubber-bonded abrasive wheel, like a Cratex polishing wheel, but cheaper than actual Cratex wheels.
EOC_Jason
Bentonville, AR
Hope these pics help. I didn't have time to take the arbor off to see the exact brand / specs for this one, but hopefully the pics give you an idea what it will do. Those were maybe like 3 seconds held against the wheel...
It works best when you are polishing a large flat surface, I like to polish the bottom of a vise slide, or the sides of a jaw.
They will deburr edges in a hurry so if you are wanting to keep crisp edges, you have to make sure you are working 90 degrees...
Like I said, think soft stone wheel. Instead of leaving those nasty grind marks this will leave a polished surface.
Farmall450
Marengo, Illinois
That's pretty sweet, thanks!
snapmom
Florida
This one works great.
rick carpenter
Huntsville, East Texas
How are the say 1" arbor Scotch-Brite wheels mounted to a 5/8" shaft? A "collar" of some sort?
In the 3M web verbage, they say that some of the Scotch-Brite wheels are suitable for finishing and polishing, with one particular wheel said to be easier than a buff and compound. Does this work well?
ZRX61
Solar Blight Valley, SoCal
I use a light green colored one, cost me $45 & that was at least 9 years ago. They place that sells them will have the collars to sleeve the shaft to fit the wheel. The ones I have are blue plastic, they were free from the abrasives shop with the wheel.
Mine gets used for tool & vise resto as well as deburring metal. My Vise photo album will show the finish on some of the jaws etc.
WWIIjeep
Arizona
Bushings, just like with grinding wheels:
The 8" and larger convolute wheels with 2" or 3" bores use stepped flange washers.
Frankly, I think they're all easier than a buff and compound. The fine EXL-series wheels won't get you a mirror finish, but the MATZ rubber-bonded wheel I showed upthread will come close. There may be something else in the 3M or Norton lines that will get you a better polish than the fine EXL, but I chose the rubber-bonded wheel for that instead.
bagged89s10
CT
I found this wheel in my dad's garage while helping him clean it out the other day. Can anyone tell what it is by looking at the pictures? All labels are missing. Looks like a scotch brite.
efb16acrx
We've got some scotch brite belts for our bench grinder belt sander attatchment at work and they last a lot longer than you'd think they would.
McBrownie
Cleveland, OH
I have one for the MultiTool belt grinder attachment and it is lasting better than I thought it would. It is surprising how much metal it can remove if you aren't careful. I have this one right now:
http://www.trick-tools.com/2_x_36_3M_Scotch_Brite_Belt_red_medium_BLT362SBM_S_10#.VYhpwyFHDZ4
And will be getting this one. Hopefully it will be a little less aggressive.
http://www.trick-tools.com/2_x_36_3M_Scotch_Brite_Belt_blue_fine_BLT362SBVF_S_12#.VYhqByFHDZ4
By the way, I don't think either of these would be good for cleaning screw threads.
